T-top shades
T-top shades
Has anyone used these T-top shades offered by Ecklers ? Their part number is 25-351153-1. I'm wondering how well they worked and stayed in place. I tried some perforated vinyl shades that was supposed to stay in place by clinging to the glass, but the key was was "Supposed" to. They didn't work very good. I love my mirrored T-Tops in the winter, but in the summer it's like sitting under a magnifying glass
if anyone has, how does it attach and did it stay in place ?
If they are what I think they are (I had a set once) they have 4 small plastic tabs - two on each side - that are to pushed in between the glass top and the plastic trim. I found they sagged in the middle and had to be stuck in place with double sided tape, which itself would release and not hold.
What I did was get some black, low knap, indoor/outdoor carpet from Lowes and cut me a set the right size using a kraft paper mock up of the cutting outline, if this makes sense. Then, purchased some 1/4" thick, dense rubber insulation and did same. Then glued insulation to carpet and then glued entire thing to roof. Has held for years now in Houston heat. Do not miss looking out the glass top.
Interesting idea. And that's the main thing, blocking the heat from the sun. That gives me some ideas that i may try. Houston is definately hot and way more humid than Dallas. Thanks for the idea !
Years ago I raised that issue with a tint shop and they said it would not work due to curvature and also concerned about heat gain on the glass (don't understand that part).
yes I did , and the heat gain was the issue. The way it was described to me was the heat rejection of the tint has a trapped layer between the tint and the glass that will cause the glass to shatter. And i'm not that willing to test that one out ;-)
So, how is that any different with a reflective insert? The infra-red (heat energy) got thru the glass to get to the reflective tint. Why wouldn't it just go thru again??? Sounds like to me...
heat gain? mmmm I smell Al Gore behind this myth....
