right mirror well nuts are rubbery material?
Old Aug 23, 2018 | 03:58 PM
pmr2000's Avatar
pmr2000
I have a replacement mirror coming today, Derby City Corvettes state it is a flawed part.
Old Aug 24, 2018 | 09:43 AM
DUB's Avatar
DUB
Do not be surprised that in time that it fails in the same spot also due to the casting may taper down thin in the area of pinching contact and can wear or get distorted it the mirror is bumped.
Then you will right back to square one and may need to use thin washers like I have had to do to tighten it up.
DUB
Old Aug 24, 2018 | 09:46 AM
pmr2000's Avatar
pmr2000
Got a replacement its sourced from Corvette America. Same issue the bracket is not a tight fit in the mirror housing.
How did you add the washers would I need to epoxy or weld them on to the mirror base or bracket?
Old Aug 24, 2018 | 10:12 AM
DUB's Avatar
DUB
I use 3M's black strip caulk to hold it in place while I slide the mirror onto the base. It has worked for me that way countless times. and I have a serious selection of thin stainless steel washers that I can choose from to get the correct thickness.
DUB
Old Aug 24, 2018 | 10:24 AM
pmr2000's Avatar
pmr2000
Thanks so much will glue the washers, this appears to be the only solution.
Should the rubber gasket sit under the lip of the well nut rubber? I put the well nut inserts in the door, then pulled the rubber circle up and over the mirror gasket. If I tried to put this gasket directly on top of the well nut inserts it sat too high.
Hard to believe both mirrors they send me were flawed, must be the way they make these reproductions.
Old Aug 24, 2018 | 03:22 PM
pmr2000's Avatar
pmr2000
Update- mirror is on with one washer! Not as tight as the left a little back and forth movement...the washer only helps the left right looseness.
Good enough for now probably will vibrate a little, thanks so much for everyones suggestions.
Old Jul 10, 2019 | 07:51 AM
ettev's Avatar
ettev
I never liked those rubber compression well nuts. I use the collapsible drywall molly anchors to mount the base to the door. Never a wobble from a rubber mount again. Rock solid.
Old Jul 11, 2019 | 02:20 PM
7T1vette's Avatar
7T1vette
The mirror base is supposed to have a vinyl gasket/shim so that it doesn't rub directly on the paint. If you did not receive that gasket, you need one. It has the thickness required and also have a raised bead which fits snugly to the outer perimeter of the mirror base, keeping water & debris out.
