Lower front valance panel needed
Old Sep 3, 2018 | 09:24 PM
RickDett's Avatar
RickDett
Default Lower front valance panel needed
1969 Coupe
Looking for a piece of the driver side front valance panel to repair this damage. Can someone guide me?
Rick
Old Sep 4, 2018 | 10:46 AM
henrikse's Avatar
henrikse
I would make it. You wold need to use some solid material for top and along opening but then layers of fiberglass cloth and then short strand fiberglass. Finish off with steel putty and sand and paint. Cheapest way. Maybe ebay or someone has a used one?
Old Sep 4, 2018 | 12:57 PM
RickDett's Avatar
RickDett
henrikese, Thanks, yes I was hoping to find a used piece, otherwise I'll fabricate as you mention.
Rick
Old Sep 4, 2018 | 06:48 PM
DUB's Avatar
DUB
You can use the other side and make 'splash mold;' and then make a part out of that mold. It could speed up your efforts.
DUB
Old Sep 5, 2018 | 02:35 PM
RickDett's Avatar
RickDett
Hello DUB not exactly sure what a "splash mold" is but I kinda got your point. Still hoping to get a used scrape piece to work with before I give in to fabricating a new piece.
Rick
Old Sep 5, 2018 | 11:02 PM
DUB's Avatar
DUB
Using the other side of your valance panel that is still intact. You apply masking tape on that spot to protect the paint. Wax the tape. Apply mat and resin enough to allow it to hold its shape and remove it and.... VOILA...you have a 'splash mold'
It will be good enough for you to wax up and then laminate it up and pull that part of your 'splash mold' and at least you would have a part that is very close to being able to install where you need it.
DUB
Old Sep 6, 2018 | 07:32 AM
derekderek's Avatar
derekderek
The term comes from pulling a mold off a boat hull. Then copying the boat by building a new one or whole line of boats with that mold. It is a splash of the original.
To Lower front valance panel needed
