Spare tire lock issue
Hello,
The spare tire lock key from my 1971 coupe has been lost, prior to my buying it.
Whats the reccommed procedure, use a sawzall to cut the bolt, replace the bolt, lock, etc?
Thank you,
Thank you,
There's plenty of threads on here regarding picking the lock. It's easy. Or just unbolt the bracket.
The key to my spare tire was long gone when I bought my 1970. I read on-line how to pick the lock with a curved dental tool. The tool was a couple bucks on eBay. It took me about 10 minutes of screwing around with the tool to pop the lock. It's really easy and now I know what I'm doing I can pop the lock in under a minute.
If you can't find the instructions on-line message me with your email and I'll send you instructions with pictures. You simply reach around the hanger bolt with the dental tool and push in the plunger. Easy-pesy...
The tire lock key is not the same as the door key? Mine is a 78.
The main bolt on mine is worn enough that I can push the lock to or side and good yank and it’ll come. Right off without a key.
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
1) Your spare tire lock is original to the car
2) You actually HAVE the original round key
Have you tried using that key to unlock it? You don't say in your original post.
Dave
In addition, there ARE glove boxes in C3's...all 1978-82's had locking glove boxes, in the dash, on the passenger side...and 1978-82's ARE C3's.
Since you don't have the oval key, then you are left to picking, drilling out, cutting, etc...the old lock off. Good advice given above.
