distributor
Old Sep 12, 2018 | 05:01 PM
Matt6969's Avatar
Matt6969
4th Gear
Default distributor
what is a good electronic tach drive distributor for a c3 1969 350 300 engine?
Thanks, Matt.
Old Sep 12, 2018 | 05:12 PM
The13Bats's Avatar
The13Bats
I bought one off ebay for my 69, hei style, tach drive but if i were to do it again i would stick an electronic module in my stock dizzy
Old Sep 12, 2018 | 05:47 PM
Matt6969's Avatar
Matt6969
4th Gear
I don't have a tach drive in it now! Just wanting a good middle of the road quality one to get my tach up and running. Don't want to spend $400 dollars on one!
Old Sep 12, 2018 | 06:41 PM
derekderek's Avatar
derekderek
https://www.ebay.com/itm/SBC-62-74-C...YAAOSwnlFae8ci
Old Sep 12, 2018 | 07:31 PM
7T1vette's Avatar
7T1vette
Just buy a used late 60's / early 70's C3 tach and have it rebuilt (or do it yourself). Most of the low-dollar items on the web are poor quality junk. Well made products are way too pricey. If all the parts are in the used dizzy and it isn't rusted solid, it can be rebuilt.
Old Sep 12, 2018 | 07:36 PM
The13Bats's Avatar
The13Bats
My ebay one was about 100 and isnt junk it might not be top end but works fine so far
Old Sep 13, 2018 | 09:00 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Here on the CF parts for sale there are tach drive dist coming up for sale all the time around $100 to $125, they sell electronic conversions for the point distributors that work excellent. When I swapped mine over I went with the Crane Fireball, another good choice is Pertronics, they sell for under $100. So for about $200 you are into a tach drive with electronic ignition. Just because I enjoy spending other peoples money, a electronic ign requires a different ign coil designed for electronic ign, also this would be a great time to have the timing curve reset on your new setup for better performance. Going this route allows you to use the OEM chrome shielding that comes stock on any 69 that came with a radio.T
Old Sep 13, 2018 | 10:09 PM
lars's Avatar
lars
Thanks, Matt.
Why...? The stock points distributor, correctly set up, will run circles around any out-of-the-box "electronic" distributor, and good points will run without adjustment for 30,000 miles.Why do you want to go with an inferior aftermarket "electronic" system? Is your car too fast, so you need to slow it down..?
Drop me an e-mail request, and I'll send you the test results of testing I did with Hot Rod Magazine several years ago comparing aftermarket electronic systems to plain ol' stock points distributor in a street driven engine.
Lars
V8FastCars@msn.com
Old Sep 13, 2018 | 10:23 PM
Matt6969's Avatar
Matt6969
4th Gear
Lars
V8FastCars@msn.com
I guess i thought it would be easier for me to set up myself and not have to worry about setting up everything!? just looking for ideas and DON'T want to Lose power!!!!! It's a 350 300 bored 30 over with HC pistons and have a hard time with the timing and fuel for it to be happy!! I'm obviously new here and don't know how to do an email request. would love to see the stats though?! Thanks, Matt.
Old Sep 14, 2018 | 07:59 AM
blue by you's Avatar
blue by you
place a WTB add in the parts for sale/wanted there are a couple of people
that have what you want
Old Sep 14, 2018 | 08:30 AM
terrys6t8roadster
Any points style distributor has wear and causes point dwell variation. When I was a teenager [5 decades ago] working at a Shell station they had a Sun 1020 with an oscilloscope that you could watch the dwell variation on new engines [3 to 7 degrees, GM the best then Ford, Mopar the worst]. Now here we are 45 years later, the shafts and bushings are worn and those distributors have even more dwell variation. So unless you either put a new shaft or have the old one built up and remachined and new bushings installed the old distributors probably have 5+degrees of point variation which causes engine misfires at higher rpm also known as power loss, whereas replacing the points with an electronic pick-up is in my opinion the easier considering the electronic pick-up doesn't care if the distributor shaft has any wobble to it. For the 4 years that I ran the Crane Fireball electronic pick-up in my 69 350 300hp with over 90k miles and buzzed that engine until the valves floated it never had a misfire and started just by touching the key after warmed up, the Holley spreadbore didn't have a choke but still started and ran better that with the Q-jet that ended up in the trash.T
Old Sep 14, 2018 | 05:44 PM
7T1vette's Avatar
7T1vette
Most of the distributors purchased from auto parts stores or on-line are junk just waiting to fail. The point of purchasing a used GM (tach drive) distributor is twofold:
1. It has the tach drive necessary to operate the tachometer;
2. It is designed with the capability of being refurbished. Bushing and gears can be replaced, if necessary. In short order, a used GM dizzy can be rebuilt to like-new or even better-than-new condition.
Unless your engine has been reconfigured with a position sensor at the crankshaft, any electronic ignition signal is triggered off the distributor output. So, the dizzy needs to be in good shape either way.
Old Sep 14, 2018 | 06:06 PM
The13Bats's Avatar
The13Bats
No hassles no power loss.....
Old Sep 14, 2018 | 09:52 PM
7T1vette's Avatar
7T1vette
Well, one satisfied customer! About 40 million satisfied GM customers who have used the stock 'points' dizzy. But, who's counting....
Old Sep 14, 2018 | 10:31 PM
The13Bats's Avatar
The13Bats
How many used HEI and complain?
Old Sep 14, 2018 | 11:22 PM
Bikespace's Avatar
Bikespace
I purchased an AC Delco 93440806 HEI distributor from eBay for half the going price. I was told it was a never run, ZZ4 take-off, and that's what it looked to be. It's worked great for my wife's 79, and looks like it belongs there, though I did have to change to an adjustable vacuum modulator, and add shims on the gear. Make sure the gear itself is compatible with your camshaft if you go this route, or get a gear that is.
I had points in my Corvair. I'd never complain about HEI, but the ignition in my LS-powered truck works flawlessly, too.
EDIT - Do take Lars up on his offer to email you his timing papers. HEI or not, following his instructions with a digital timing light and some tuning will make your car much happier.
To distributor
