volt meter gauge
Old Oct 12, 2018 | 08:33 PM
TPI BOY's Avatar
TPI BOY
Default volt meter gauge
A 75 has a amp meter I want to change it to a volt meter, should I use the 77 gauge or the 78 gauge? and whats the difference
Old Oct 12, 2018 | 08:41 PM
TPI BOY's Avatar
TPI BOY
Also where can I buy one
Old Oct 12, 2018 | 09:10 PM
C3 Stroker's Avatar
C3 Stroker
For a '75, I would use a 72-74 Voltmeter gauge since it fits the bezel exactly and more closely matches the other gauges. You can actually use any voltmeter gauge that fits, since you only need a hot wire (+12v) to it. It is grounded to the bezel when it is re-attached. The old ammeter connection is not used.
This one will work.......https://www.zip-corvette.com/72-74-v...gine-swap.html
Old Oct 13, 2018 | 06:28 PM
TPI BOY's Avatar
TPI BOY
so all years will fit, but might not color match, is that right
Old Oct 13, 2018 | 07:24 PM
mrvette's Avatar
mrvette
A gauge from an 80's pickup will work fine, same black but the script is different.....bolt in.....
Old Oct 13, 2018 | 09:28 PM
TPI BOY's Avatar
TPI BOY
no, want one out of a c3, just want to know
what will fit, looks like I will get the 74
Old Oct 14, 2018 | 01:35 AM
Strokemyaxe's Avatar
Strokemyaxe
Does the amp meter work?
Old Oct 14, 2018 | 12:03 PM
TPI BOY's Avatar
TPI BOY
nope, broken
Old Apr 27, 2020 | 09:51 PM
Dagious's Avatar
Dagious
check with Corvette Central. I believe they have both green and white lettering.
Old Apr 27, 2020 | 10:07 PM
Mooser's Avatar
Mooser
Hopefully he's got it solved by now....
M
Old Apr 28, 2020 | 09:12 AM
7T1vette's Avatar
7T1vette
Oh, I hope so.....
To volt meter gauge
