Tilt-Wheel Steering Column Issue
Old Oct 22, 2018 | 01:50 PM
Goin70's Avatar
Goin70
Default Tilt-Wheel Steering Column Issue
Need some advice ... My tilt-wheel steering column in my 1970 works fine, but it's "loosy-goosy" and feels terrible when you hit a bump. Should I have my shop rebuild the original, or get something like an aftermarket "I Did It" steering column? If a rebuild, what's needed for parts and where can you buy them? Thanks!
Old Oct 22, 2018 | 05:33 PM
mrvette's Avatar
mrvette
Many times there are 4 bolts holding some housings together, buried down under/behind the turn signal switch, and that means pull it ALL apart, a super PIA......
My column in my '72 came from a late shark, smaller wheel, and dimmer on T/S lever....I was told it went through a collision when I bought it, there is some looseness in the column that is NOT due to the 4 bolts, but it's been fine since '95, so hell with it....BUT you HAVE to know them bolts are tight, and check it all out for sure, so nothing stupid happens.....
Old Oct 22, 2018 | 05:48 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Look for Jim Sheas papers and look for Dub,he will guide you along. The column works great when you
get all the little things worked out.
To Tilt-Wheel Steering Column Issue
