Speaker sound
Old Dec 20, 2018 | 08:23 PM
LuisChevere's Avatar
LuisChevere
Default Speaker sound
Hey all,
i have a 1975 stingray and I’m having some audio issues. I have a custom autosound usa1-r on my car. I’ve had my speakers properly rewired with new wires and an amplified added. I also have a suppressor connector to my alternator but when I turn my engine on, I get a high pitch squealing coming out of my speakers, it doesn’t do it all the time but when it does, it’s so loud, I have to turn the radio off. The guy who did the work said it could be something within the radio itself that is causing the issue but I can’t figure it out. The radio has been discontinued so I can’t replace it but I am not willing to let it go. Any suggestions on what to do would be appreciated. Thank you in advance.
Old Dec 20, 2018 | 11:51 PM
Antz81's Avatar
Antz81
Originally Posted by LuisChevere
Hey all,
Unfortunately I think the radio guy could be right. Only way to confirm it is to replace the radio and see what happens. My brother had the same think in his '82 C10, new radio solved it.
Old Dec 20, 2018 | 11:53 PM
LuisChevere
I’m gonna search locally for a radio repair shop. Hopefully they can fix whatever it may be, I’ve spent so much money on this radio. I can’t let it go. Hahaha
Old Dec 21, 2018 | 08:55 AM
M Pete's Avatar
M Pete
If the noise increases with RPMs it may be a bad ground for the radio.
Old Dec 21, 2018 | 09:24 AM
3Vettes739213's Avatar
3Vettes739213
I installed one of those “slide-bar” type that looks like an original AM radio till you slide it to reveal the digital face. 1 month out of warranty the stupid slide bar broke. Just a warning if you or anybody else goes that direction. I have had a new USA-230 for 9 months ready to install in a 73 when I get a round-tuit. Please post your solution or resolution. Those bugs can be frustrating.
Old Dec 21, 2018 | 09:53 AM
LuisChevere
so should I upgrade my ground to a 10g? I have that. The current ground cable is rather thin so I’ll give that a try.
Old Dec 21, 2018 | 10:46 AM
henrikse's Avatar
henrikse
Does the radio have noise when the engine is not on? Bigger ground will not make a difference. There are various noise filters out there and if it is the radio not hard to fix. Find a repair shop in your area
Old Dec 21, 2018 | 12:14 PM
ddawson's Avatar
ddawson
Did he wire everything to the battery? I ran my Stereo and AMP directly to the battery.
Then I ran the ignition wire that that turns everything on to a relay and wired the output to the battery.
My noise was a loud crack when I stepped on the brake. Now no more noise.
Old Dec 21, 2018 | 12:18 PM
LuisChevere
yes, a rattling and a slow pitch. I’ve got a suppressor attached to the alternator and just ordered one that connect to the flasher cable. The manufacturer said it’s probably a bad ground so to rewire it to the chassy which a few others have said. So I’m gonna take it back to the radio shop that did my wiring to rewire that. Hopefully it works, if not, it’s gotta be something in the radio itself.
Old Dec 21, 2018 | 12:20 PM
LuisChevere
the amps are through the battery, not sure about the radio, I’ll ask when I take it back in. My noise is a high pitch noise when my rpms go up and engine is on but the whining is low.
Old Dec 21, 2018 | 12:26 PM
M Pete's Avatar
M Pete
I have been told, and read on Crutchfield that it is best to run at least the ground direct to the battery. Also the actual battery ground (located on the frame under the battery compartment) may need some cleaning. I have an alternator whine (increases with RPM) in my audio setup which is using the factory ground wire and will be switching things up this week.
Old Dec 21, 2018 | 12:39 PM
LuisChevere
I’ll let them know when I take it back in! Thank you!
Old Dec 23, 2018 | 04:22 PM
M Pete's Avatar
M Pete
So here is the Paul Harvey Rest of the Story for mine. I was able to isolate the source of the noise. The setup I am working on is no radio, Bluetooth module going to a mini amp powering the speakers direct. It turns out, after working with many different combinations my bluetooth module was what was making the noise no matter how it was hooked up (even going directly to the battery + and -). Those are the chances you take with a $20 module I guess. I double checked by plugging my phone directly to the amp with a head phone jack to RCA cable that I had made and it worked just fine. That is a good way of testing if the fault is with the amp or audio source.
Old Dec 23, 2018 | 05:59 PM
LuisChevere
im having my grounds redone tomorrow and possibly adding an rca noise suppressor. Let’s hope it works!
Old Dec 23, 2018 | 06:39 PM
Richard454's Avatar
Richard454
You say "it doesn't do it all the time- but only when the engine is running."
And if you turn it off - but then back on -it stops squealing?
If so - it sounds like a bad solder joint- in the radio or amp. What's happening is feedback- sort of like when the guy on stage with the microphone gets too close to the speaker and a squeal results. It could possible be a bad connection in the RCA cables- but it doesn't really sound like it.
When this happens- tap on the amplifier -or radio and see if it stops-if not then un-plug the amp.
Let us know what you find.
If it's not doing all the time then no amount of filters are going to solve this problem.
Richard
Old Dec 23, 2018 | 09:21 PM
LuisChevere
Richard
it happened before the amps, they’re going to reground it tomorrow so let’s hope that’s it. I’ll keep you guys posted on it!
Old Dec 23, 2018 | 10:49 PM
Richard454's Avatar
Richard454
A bad or high resistance ground would give you the alternator whine- that changes with the pitch with respect to RPMs. It's basically unfiltered AC ripple from the alternator. You can disconnect the alternator - and if the noise is still present then it's not a bad ground- and a filter will not stop it. It really sounds like the radio's internals.
Just sayin-
Richard
Old Dec 23, 2018 | 11:43 PM
LuisChevere
Just sayin-
Richard
yeah, that’s what I’m afraid of as this stereo isn’t made anymore and I’m wanting to keep the vintage so if it is. I may find some place that could possibly fix it.
To Speaker sound
