Let the fun begin.
I made each one 16 inches so I could get an equal amount out of an 8 foot 2x4. And yes they are screwed together and work great. Just figure how high you want to go and then get the wood.
St. Jude Donor '19-'20-'21-'22
Did you use standard pine 2x4's? Also, being approx. 12" high, how hard is it to jack the car high enough to place the wheels in them?
fastimes (02-13-2019)
A little update on my work. I have the body bushings done. Cleaned up some more of the front frame. Disassembled the car. Stripped all the paint. Did what ever body work turned up. Now I am putting it into feather fill and then block sanding it. I have probably painted about 15 vettes and if you ever get to do one you will realize why people charge $15000 to paint one. Between stripping it and primer and blocking. Then the paint and buffing. It is alot of work. Just masking the car can take few hours. And that has to be done between each step. I am about half way now. I plan on painting it in May. After paint I still have the Holley Sniper fuel injection to get done.
The following 2 users liked this post by 540 vette:
arcticdoggie (02-17-2024),
OldCarBum (02-17-2024)
It's been 5 years, since post #1. How's the project going?
