console lights
Old Jan 9, 2019 | 01:14 AM
75MM's Avatar
75MM
Default console lights
Hi. my shifter light and heater control light and ashtray light in my 75s console are all out. All gauges and dash lights are ok. The fuses all look ok but havnt took any out yet. I checked the bulbs. Ill pull and change fuses first then take it all apart tomorrow to see why. Has anyone ran into this one before? or have any suggestions?
Old Jan 9, 2019 | 07:32 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Make sure your console is grounded. Quick check can be made by running a jumper wire from the battery to any metal surface on the center console (ash tray) to see if they light up.
Those bulbs should be on the same circuit & fuse as the dash lights.
Old Jan 9, 2019 | 08:30 AM
7T1vette's Avatar
7T1vette
Actually, you can run that jumper from any grounded surface (metal in dash area, (-) pin in fuse box, etc. to a bare metal surface or screw in the console. If those bulbs light up, you just need a good ground connected to that area. If not, the bulbs are bad.
Old Jan 9, 2019 | 11:09 PM
75MM's Avatar
75MM
Thanks that was it. I forgot to hook it back up when I tracked down the bad door ajar buzzer that kept blowing the fuse Now all three lights are burning. Thank you both very much.
To console lights
