C3 led headlight conversion
Old May 1, 2019 | 03:28 PM
C3 Stroker's Avatar
C3 Stroker
Originally Posted by ivanh3
Did you ever install these? I am wondering if the bucket (or anything else) needed modification.
Not yet, but next to do on my list. Carb and spring tune-up done. I will start a new thread and update on this install soon.
Old Jan 21, 2020 | 10:41 AM
Red_LS7's Avatar
Red_LS7
sorry to bring an old post back to life. Can anyone provide tips on how to install these lights? I have an 81 and I've tried installing them but the back part of the light won't fit into the bucket. Seems like I will have to modified the bucket (cutting the hole bigger) in order to secure the lights.
Old Jan 21, 2020 | 01:34 PM
Richard454's Avatar
Richard454
As far as modding the bucket to make it larger- here's how I opened it up and made it pretty-
A scrap piece of metal- vice gripes and a hole saw-
Drilled a pilot hole and aligned it up in the middle- carefully used the hole saw- it's potmetal- pretty easy to drill.
Old Jan 21, 2020 | 02:49 PM
Red_LS7's Avatar
Red_LS7
Thanks Richard454.
Old Jun 19, 2020 | 12:16 AM
Wmacky's Avatar
Wmacky
Originally Posted by C3 Stroker
You can get them through Amazon, even though Octane's website shows no stock. That's where I got mine. Here..https://www.amazon.com/Octane-Lighti...ng+5+3%2F4+led
Not anymore. These seem to have disappeared. any other options?
Old Jun 19, 2020 | 09:05 AM
Yadkin's Avatar
Yadkin
HELLA 002850811 135mm H4 High/Low Beam Halogen Conversion Headlamp Kit
No cutting or other BS.
Old Jun 19, 2020 | 10:26 AM
ivanh3's Avatar
ivanh3
Did you call Octane Lighting? It seems the model numbers or offerings change a lot both on Amazon and Ebay. If you haven't, then call Octane and tell them what you want. They will tell you what they have. That's what I did and the sales rep sent me to an ebay auction. I could have also purchased right there on the phone, but it was just easier to go to Ebay.
Old Jun 19, 2020 | 10:55 PM
Wmacky's Avatar
Wmacky
Do you have a link?
I did talk with them, but they said the 4000 lumen units were out of stock for a few month and would require bucket trimming. Something must have changed?
I had found a similar set from Octane on Ebay that they recommended as a exact fit, The lenses seem the same but Lumen s are listed as 2500, vs 4000 of the set posted above? would they be bright enough?
https://www.ebay.com/itm/232524982002?ul_noapp=true
Old Jun 20, 2020 | 01:37 PM
ivanh3's Avatar
ivanh3
Do you have a link?
I will post a link to a post I made here on the forum with a video, some pics, and a brief discussion of a little bit of weirdness I had to do to get them to work that probably wouldn't apply to most people. The post also has a link to the Ebay auction I was directed to by Octane staff, but when I click on it, the page says updated by seller. The price is about 20 dollars higher than I paid. They are listed at 2500 lumens which I what I am pretty sure mine are. They are plenty bright for me, and have held up so far. Check out the link.
Ivan
https://www.corvetteforum.com/forums...post1600450160
