Brake pads
Old Feb 15, 2019 | 07:28 AM
crap's Avatar
crap
Default Brake pads
Are the brake pads on a 1975 Corvette Stingray the same pads for each caliper. Or do the back ones take a different pad than the front ones?thanks sgain
Old Feb 15, 2019 | 09:33 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
They are the same. For a high quality street pad you should consider the Carbotech 1521 pad.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Feb 15, 2019 | 09:37 PM
7T1vette's Avatar
7T1vette
One usually puts the same pads all-around. The only MUST is to put same pads on both sides of front OR rear wheels. Not sure what advantage you would get making front and rear different....unless the brake system has some weird problem that installing different pads corrects.
To Brake pads
