1969 Interchangeable Parts
Old Mar 10, 2019 | 06:07 PM
LZDICK's Avatar
LZDICK
Default 1969 Interchangeable Parts
I have a question from a potential buyer regarding items I have for sale on the Forum's Parts for Sale page. I am NOT very knowledgeable on these cars; perhaps a Forum member could chime in with the correct answer to help with the sale.
Are the 1969 kick panels (item #2) and defroster grille (item #3) interchangeable (the same part #) between coupe and convertible cars?
Thanx, in advance, for your response.
Rich
Old Mar 10, 2019 | 07:05 PM
DUB's Avatar
DUB
YES...they are the same.
The only difference in the kick panels may be if your car has A/C or not. I believe....if my memory serves me correctly....that a NON-A/C cars right kick plate is different than that of a A/C equipped car. A kick plate on the rigth side on an A/C car has more plastic cut out on it for the vacuum pod for the fresh air vent.
DUB
Old Mar 10, 2019 | 07:56 PM
LZDICK's Avatar
LZDICK
DUB,
Thank you for the explanation.
Rich
Old Mar 10, 2019 | 11:46 PM
7T1vette's Avatar
7T1vette
If I remember correctly, the A/C and non-A/C use the same kick panel. But there is an area cut out of it [for clearance] on the A/C version. And I believe that is the way it was done even at the factory.
Old Mar 11, 2019 | 06:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 7T1vette
...If I remember correctly, the A/C and non-A/C use the same kick panel. But there is an area cut out of it [for clearance] on the A/C version. And I believe that is the way it was done even at the factory...
Yep. Passenger's side kick panel gets trimmed to clear the vacuum actuator on factory air cars.
Old Mar 11, 2019 | 06:51 PM
DUB's Avatar
DUB
Yep..as I wrote in post #2
DUB
To 1969 Interchangeable Parts
