Paint type.
Old Apr 8, 2019 | 03:42 AM
drewbear's Avatar
drewbear
7th Gear
Default Paint type.
Hello all from Australia.i have a 69 vette that is almost ready for paint.i like burgundy.i just want people’s opinions.should I go the original non mettalic,or go a mettalic.just want people’s thoughts,thanks in advance.
Old Apr 8, 2019 | 06:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your choice. It's your car.
Old Apr 8, 2019 | 06:57 AM
drewbear's Avatar
drewbear
7th Gear
True that
Old Apr 8, 2019 | 07:05 AM
Rotonda's Avatar
Rotonda
As a general rule:
1) lighter colors will tend to conceal more of the flaws in the substrate, and
2) metallic will tend to emphasize flaws in the substrate more than a solid version of the same color.
3) metallic's usually require more experience to lay down without noticeable variation than do solid colors
If you are confident that your prep work has given you a flawless substrate and you (or your painter) has the experience, go with the maroon metallic. Otherwise locate someone with experience and go back to your prep work. See Easy Mike's advice above.
Old Apr 8, 2019 | 07:16 AM
drewbear's Avatar
drewbear
7th Gear
Thanks I was thinking maroon as well.i just wasn’t sure what way I’m going as the car is original,and burgundy was one of the original colours of that era.
Old Apr 8, 2019 | 09:51 AM
7T1vette's Avatar
7T1vette
If you want people to actually look at your car and you're going to paint it burgundy, put metallic in it. Maybe a really fine gold or red....or both. 'Flat' burgundy might be the original color, but the 'Earth color' days of the 1970's are over! The paint needs to 'pop' to get someone's attention.
Now, if your idea of "success" is to have an NCRS judge say to you, "Nice paint", have at the non-metallic burgundy.
Old Apr 8, 2019 | 09:58 AM
cv67's Avatar
cv67
St. Jude Donor '05
^^Metallic really makes the body lines pop, C3 definitely has that going for it. Up to you how ""big" your metallic looks.
Dont listen to any voice but your own when it comes to choosing paint, you have to love it we dont
Old Apr 8, 2019 | 12:38 PM
20mercury's Avatar
20mercury
If you decide to go with the 69 Corvette original Burgundy 988, then it is a metallic, see link
http://corvettepaintcodes.com/
I believe the amount of metallic in the original 988 is not a whole lot compared to modern views on metallic. You can also check out 69 Burgundy paint jobs on the internet to view some photos. And last, you could talk to your local PPG rep who might mix you a sample to view.
Hope this helps and good luck. I have a 69 that is originally Cortez Silver, that I believe I going to paint the original 988 Burgundy as well.
Old Apr 8, 2019 | 12:45 PM
71 Vert LS1's Avatar
71 Vert LS1
One of things I've done to pick out a paint color is spend some time driving around new/used car lots looking at paint colors. I find it easier to see it on a car not just a paint chip. Also if you choose a current car color it's easier to match if something happens and you need to match the paint
Old Apr 8, 2019 | 05:28 PM
drewbear's Avatar
drewbear
7th Gear
Thanks for your input.i will go metallic.
Old Apr 8, 2019 | 06:24 PM
ignatz's Avatar
ignatz
The one thing about metallics I will caution you about is to orient the objects to be painted as they would appear on the car. It's tempting to lay the doors flat ... don't. The metallic "settles" in a different orientation and that drastically changes the color, especially with darker colors. Also, a final light 'drop coat' really brings out the sparkle.
Old Apr 9, 2019 | 03:21 AM
drewbear's Avatar
drewbear
7th Gear
Thank you
Old Apr 9, 2019 | 03:22 AM
drewbear's Avatar
drewbear
7th Gear
Thank you
Old Apr 9, 2019 | 09:06 AM
540 vette's Avatar
540 vette
It depends on who is painting the car. If you are having it done professionally then anything you want. But if you are doing it in your garage stay with a solid color.
Old Apr 9, 2019 | 02:22 PM
71 Vert LS1
Typically when spraying metallics all the panels should be bolted on the car and sprayed all at once so the panels match. Solid colors can be sprayed piece by piece.
To Paint type.
