1975 C3 corvette with a 350. I just replaced a defective ignition module The timing fluctuates at idle. When I reattach the vacuum hose, the engine dies. Do I have bad springs or weights in the ignition distritutor? When I disconnect the vacuum hose from the distributor it seems the engine runs ok.
If you mean the timing mark fluctuates at idle, that's par for the course with some timing lights. They have difficulty receiving a good signal from the plug wire then relaying that impulse through the light. The light beam will jump between two known marks.. You have to figure out which is correct. Usually the lesser mark..
I doubt the actual timing is moving but maybe. If the engine dies with Vac, you must be too advanced. Plug the Vac off, loosen the dizzy and set your total around 34-36 at a high RPM, above 3K. Once that is set and locked down, then reattach the Vac. By the way, the Vac line moves the plate under the weights & springs. Two different systems: Mechanical Adv and Vac Adv.
On the springs & weights? Hard to say unless the timing TRUELY is all over the place. But for now get your Total Timing (w/o vac) established.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just an FYI item to check. On old vehicles with an HEI distributor, it's not uncommon for one of the two wires connecting the pickup coil to the ignition module to fatigue/break due to the wires flexing every time the vacuum advance canister rotates the "breaker" plate. Perhaps a resistance/continuity check of the pickup coil while moving the "breaker" plate might be an item to consider checking.
Thanks for your help. I'm going to get a good timing light and check it again. Prior to that, I've ordered and new ignition coil module. I noticed the three wires to the coil are frayed and may be arcing or miss firing.
That reminds me of something else. Remove the coil dust cover, three phillip screws. On one corner of the "coil in cap" is a GRD wire under one of the four mounting screws. Sometimes the coils are painted so well that a good Grd is impossible. Remove that Grd wire and screw. Take a small wire brush and remove the coating on the coil where the GRD wire goes. Put it all back together.
replace distributor pickup assembly ... Standard Ignition pn LX-302 ... or ... LX-302T
your timing is way off. advanced too far. get a timing light.
I cranked the engine over until I got the line on the harmonic balancer to TDC. I then removed the distributor cap to check to see if the rotor was pointing to the number one plug wire. It was pointing 180 degrees off. It looked like I have the rotor on backwards. What am I doing wrong?
You're probably TDC on the exhaust stroke, instead of the compression stroke. The crank (and harmonic balancer) goes around twice for each cycle of the rotor. Crank the engine one more revolution, and your rotor should be lined up.
