Made some progress on the interior
Old May 25, 2019 | 08:10 PM
AdamMeh's Avatar
AdamMeh
Default Made some progress on the interior
Long weekend and nice temps, so I'm trying to take advantage of it before summer hits. Pretty happy with the project so far.
The before shot is from January when I gutted it. This all started with a little bit of smoke from under the dash while starting the car. The "while I'm in there" syndrome has taken over... again.
Old May 25, 2019 | 08:36 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
That is a great decision using soundproof-insulation. My car is much quieter inside and the floorboard-gas pedal areas have dropped 30*F......(ambient temp. Plus 2 * F) .
Old May 25, 2019 | 10:51 PM
7T1vette's Avatar
7T1vette
Yep, it's really quiet sitting in the garage Kidding!!! Looks like a good start at a solid interior build.
Old May 25, 2019 | 11:21 PM
AdamMeh's Avatar
AdamMeh
Super quite - can't even hear it running. I think it will be worth it when it's done, and no more melted 40 year old wiring. Considering we had no fan, vent controls, AC, heat or wipers, this will be a huge step forward.
Old May 25, 2019 | 11:22 PM
AdamMeh's Avatar
AdamMeh
I'm hoping for results like that! If I can drive it when it's a 100 out, sit in traffic, stay cool and the car doesn't overheat I'll be thrilled. LOL
Old May 26, 2019 | 06:57 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Its a good feeleing not being panicked when I see a sea or tailights in front of me
Old May 26, 2019 | 07:43 AM
7T1vette's Avatar
7T1vette
Other critical areas for heat "prevention": refresh the seal on the kickpanel vent doors (especially on A/C cars); rear hood seal; firewall insulation; transmission shift boot seal.
Old May 26, 2019 | 10:05 AM
AdamMeh's Avatar
AdamMeh
Done, done and done. I will replace the hood seal as well, but not quite to that stage of the body work at this point. I still need to order the collar seal for the bell housing. Should be able to do that now that the firewall and cowl detailing is almost done.
Old May 28, 2019 | 10:06 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Adam, also make sure you have the under-body tunnel seal as well as the foam collar that push's up between the firewall and then bellhousing.
Old May 28, 2019 | 10:53 AM
AdamMeh's Avatar
AdamMeh
Thanks Willcox - The trans tunnel insulation requires the trans to be dropped correct? If so, that will have to be next fall. Getting a little hot here to lay under a car in the garage. Also - what type of adhesive do you recommend for the collar?
Adam
Old May 28, 2019 | 12:26 PM
0Willcox Corvette
Former Vendor
Adam
On the foam... you'll need to make sure the bellhousing is clean first. We use Weldwood glue but you won't have that and I doubt you'd want to buy a gallon of it. You could probably get away with 3m fast tack trim adhesive. Spray it on the foam, spray it on the firewall and the bellhousing and allow to dry, then spray a wet coat on the foam again and install.
The tunnel insulation requires you to remove the shifter only... I've seen people install them before by cutting them in half and then using the aluminum foil tape to put it back together. I'd not suggest that method though. But they are a royal pain to install.
Willcox
Old May 28, 2019 | 04:31 PM
AdamMeh's Avatar
AdamMeh
Willcox
Thanks again. I need to check on the tunnel. I can't remember seeing any clips in place for the tunnel insulation, but it's been awhile since I was under the car. I have some 3M 77 and also a can of their headliner adhesive (both spray versions). Would I be better off to use the trim adhesive you mentioned?
Old May 28, 2019 | 07:09 PM
0Willcox Corvette
Former Vendor
Adam, I'd use what you have.... the weldwood is pretty expensive and you have to buy it in a gallon minimum. There should be four clips under the car to hold the tunnel insulation in place.
E
Old May 28, 2019 | 09:09 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Or you could use drywall screws like the previous owner of my car did. I kid you not.
Old May 29, 2019 | 12:57 PM
AdamMeh's Avatar
AdamMeh
E
Our car is a '77. Did they have the tunnel insulation?
Old May 29, 2019 | 12:59 PM
AdamMeh's Avatar
AdamMeh
The bubba force is strong in these cars isn't it.
Old May 29, 2019 | 02:26 PM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
I put the sound proofing in when the interior was replaced, great decision!
To Made some progress on the interior
