Bilsteins
Old Jun 1, 2019 | 06:43 PM
Tbone4432's Avatar
Tbone4432
Default Bilsteins
I want to have Bilsteins installed on my '77. Heavy duty m, Sport or combination?
Old Jun 1, 2019 | 08:15 PM
Black4speed's Avatar
Black4speed
I went from AC Delco to Bilstien B6 front and rear I'm very pleased.
Old Jun 1, 2019 | 11:49 PM
JoeMinnesota's Avatar
JoeMinnesota
Same here - also very pleased.
Old Jun 2, 2019 | 09:50 AM
obas's Avatar
obas
I went with the Sport for the firmness in the corners but pay the price on rough sections of roads. I think the choice depends on driving habits and the road conditions where you typically drive.
Old Jun 5, 2019 | 02:27 AM
Lakeside49's Avatar
Lakeside49
I agree with "Obas". If you like to drive in a high spirited way, particularly in corners with irregular surfaces that need help keeping the suspension stable and sticking to the road go "sport". I went with the less aggressive "heavy dutys" and could not be more pleased. The trade-off in slightly superior cornering (mainly if uneven terrain) at the expense of normal road cruising with my wife made the sports a non-starter. And, trust me, the HD's are no performance slouch - they perform superbly - whenever you do have an urge to put it through its paces.
The only thing is, I painted mine black. I know its a personal preference whether to showcase to fellow enthusiasts driving behind you that you have upgraded to gas shocks. But, I simply couldn't get past that gawdawful trademark Bilstien color combination that must have been decided while under the influence of something.
Good luck -
D
Old Jun 5, 2019 | 11:36 AM
7T1vette's Avatar
7T1vette
If your rear spring is still steel, go with HD's at all wheels. If you have a mono-spring in back, put Sport's in the rear. If you have done a lot of 'stuff' to the suspension to make it handle much better, you could go with Sport's all-around. If the suspension is basically stock, I'll stay with my initial recommendation.
Old Jun 5, 2019 | 12:13 PM
mdeslyper's Avatar
mdeslyper
I am also looking at installing B6 all around. My car has a VBP mono rear spring. Why do you recommend the B8 in back?
Old Jun 6, 2019 | 02:21 PM
7T1vette's Avatar
7T1vette
My '71 has a monospring. I installed Heavy Duty unit at all corners. Upon driving it, the rear is not as "controlled" as I would have liked it, while the front is just fine. I think Sports in back would have made it ideal. I'm OK with the result and would not spend more money to swap out the rear shocks. But I wish someone would have told me to use Sports with the monospring.
Old Jun 6, 2019 | 02:41 PM
JoeMinnesota
I’d agree with 7T1. I have the B6’s all around with a 330 rear mono leaf. It’s a good ride and decent handling, but Sports out back would have pinned the car down just a bit more.
Old Jun 7, 2019 | 06:39 AM
Bikespace's Avatar
Bikespace
I went with Sport rears, HD fronts. 385 lb composite rear springs, 550 fronts. The front is a bit bouncy, and the rear could use more spring (though the sway bar helps.) My 80 is lighter in front than many, and has a stock 1 1/8 away bar and fresh bushings.
I'll probably put in coil-overs someday, vs. Sport fronts, so it's okay for now.
Old Jun 7, 2019 | 09:16 PM
mdeslyper's Avatar
mdeslyper
Thanks for info. I just use my vette for cruising around on the weekends (no track time). Would you still advise the B8s in back for this application?
Old Jun 7, 2019 | 09:35 PM
JoeMinnesota
For generals cruising I'm happy with the B6's. I think it would depend a little on your spring firmness in the rear. If you're 330 or over probably fine with B6's. If you have a softer spring I'd consider the B8's. My personal opinion. I am also running 8" bolts, but you probably have height figured already if you have the spring in.
Old Jun 8, 2019 | 07:44 AM
Black4speed
No, you should be good with B6s front and rear.
Old Jun 8, 2019 | 09:57 AM
mdeslyper's Avatar
mdeslyper
PO installed the mono spring. Not sure how to tell spring rate. Thanks for all the comments/info.
To Bilsteins
