Looking for engine
Old Jun 4, 2019 | 03:28 PM
  #41
bashcraft's Avatar
bashcraft
Originally Posted by C3ForLife1968
He is probably the best mechanic in my area.
So you're saying that there are no competent mechanics in your area?
Sorry to tell you guys, but a 4 bolt is the only option for me,
Sounds like you know even less about engines than your mechanic does. That's unfortunate, for your bank account.
Old Jun 4, 2019 | 05:07 PM
  #42
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Either one of those is a good option. They both have nice reasonable roller cams and good vortec iron heads and should last basically forever.
The 4 bolt version has a brand new block and intake and carb, so it is more complete.
But it won't last a minute longer or make 1hp more just cause it's a 4-bolt.
It's your money....
Old Jun 6, 2019 | 07:07 AM
  #43
C3ForLife1968's Avatar
C3ForLife1968
Originally Posted by jackson
You'd best saddle-up and move pard
this is better https://www.summitracing.com/parts/nal-19367082
I'm done.
It has a flexplate and a long water pump, two things i don’t need🤔
Old Jun 6, 2019 | 10:00 AM
  #44
caskiguy's Avatar
caskiguy
Hi goodpeople. I am looking for a engine for my 1968 Corvette. I can not use the old one since it is a 2 bolt. I don’t want an engine with a crazy amount of horespower, somewhere around 300 would be nice. I am looking for a complete engine with carb. So far I have found this https://blueprintengines.com/product...or-bp35511ctc1 it doesn’t have to high compression ratio, which i want. Do you have any other recomandations or is this the perfect engine? Your answer is much appreciated
Highly recommend you speak with Johnny McDevitt at Blueprintengines.com
# 1-800-483-4263 Ext. 1010
He'll take very good care of you.
