Looking for engine
Old Jun 3, 2019 | 04:18 PM
C3ForLife1968's Avatar
C3ForLife1968
Originally Posted by drwet
You don't need four bolt mains if all you want is 300 hp.
My old engine got it’s crank bearings worn out because it was a 2 bolt. That engine had 300hp. I just want an engine that will last a lifetime
Old Jun 3, 2019 | 05:23 PM
L-46man's Avatar
L-46man
Wait what...'you cannot use it because it's a two bolt'????? Hornswoggle!
Sure you can! There is nothing wrong with a good 2 bolt up to 350 hp.....even more.
Just don't go nuts with the comp ratio. Have a good forged crank would be 'nice' but not necessary.
Good luck....
another internet 'myth' bites the dust!
Unkahal
Old Jun 3, 2019 | 06:15 PM
drwet's Avatar
drwet
Your bearings didn’t wear out because you have 2-bolt mains. If that’s what your mechanic told you, find a new mechanic. Thousands of small block Chevies have run hundreds of thousands of miles on 2-bolts. 300 hp does not require 4-bolt mains.
Old Jun 3, 2019 | 06:23 PM
L-46man's Avatar
L-46man
OMG....this must NOT be a screaming deal......only because it's a two bolt main! You can see the crank journals....they MUST be ruined because it's a two bolt main!
https://phoenix.craigslist.org/cph/p...901162663.html
Old Jun 3, 2019 | 07:28 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Your crank bearings wore out for some other reason, but it had nothing to do with it being a 2 bolt main. More likely is the cam wore out, due to no zinc, and the particles took out the bearings. Check for rounded cam lobes, or loose rocker arms, and then you'll know. With today's almost no zinc oils, you'll want to build a roller cam motor (street version). Just so it'll last forever no matter what kind of oil you toss in it. And use the two bolt block. Four bolt blocks go for $500 around here, and the shipping to Norway would cost a lot too. You'd be money ahead to put that $800 towards a roller. Or find a later model 350 that already has a factory roller in it.
GM first began installing roller cams in some Chevrolet small-block, V8-equipped cars in 1987. But OE roller-cam installations in trucks didn't occur until 1995
Old Jun 3, 2019 | 08:26 PM
ddawson's Avatar
ddawson
I see reliable and longevity but your looking at a flat tappet cam. Look for a roller cam setup instead.
Old Jun 3, 2019 | 09:51 PM
jackson's Avatar
jackson
I've told you what's wrong with that overpriced BP piece ... now here's a practical solution:
Just about the best deal there is, certainly THE best I know of.
Brand New GM L31 Vortec 350 ... 255 HP ... Vortec heads, Roller Cam & Lifters. Well Under $2000 All Brand New. Add a little bigger cam, a Vortec intake manifold, a melonized distributor gear, electric fuel pump etc... all WELL UNDER $1000 and it'd easily make 375-400HP Robust, Durable RELIABLY.
https://www.ebay.com/itm/GM-OEM-NEW-...frcectupt=true
FWIW, I knew a Norwegian biker who lived in Charleston SC ... BIG cat who rode an equally BIG Kannon with Vortec V8 power.
Old Jun 4, 2019 | 03:47 AM
C3ForLife1968
Good luck....
Unkahal
the compression ratio was 10,5:1, way to high!
Old Jun 4, 2019 | 08:13 AM
jackson's Avatar
jackson
For most street & some racers, cast crank is Not a limiting factor.
e.g. Overwhelming majority of GM LS motors making up to ~500 hp sold new with cast cranks ... including LS3.
Old Jun 4, 2019 | 08:15 AM
C3ForLife1968
So the Blueprint Engine I found is good enough? https://www.summitracing.com/parts/mll-bp35511ctc1
Old Jun 4, 2019 | 10:36 AM
Kacyc3's Avatar
Kacyc3
theres a debate going on in another thread about the way engines are rated. The 310hp engine when put in the car will not be 310rwhp on a dyno, if you want 310 rwhp you need to look at engines rated at 400. Go here and read before ordering. https://www.corvetteforum.com/forums...rear-axle.html
Old Jun 4, 2019 | 10:54 AM
C3ForLife1968
Thanks for the advice, but my main focus is to get the car going again and i don’t want to brake the bank either
Old Jun 4, 2019 | 11:37 AM
  #33
Kacyc3's Avatar
Kacyc3
If you are set on blue print engines why not this one https://blueprintengines.com/product...lock-bp3503ct1 its more power than the ones you listed, it has all the features we are telling you to get and its cheaper. You will need a new intake manifold but your still better off.
Old Jun 4, 2019 | 12:04 PM
  #34
C3ForLife1968
I will take a look. Thank you
Old Jun 4, 2019 | 12:07 PM
  #35
C3ForLife1968
It’s a 2-bolt though 🤔
Old Jun 4, 2019 | 12:14 PM
  #36
Kacyc3's Avatar
Kacyc3
Just have your mechanic order one for you.
Old Jun 4, 2019 | 12:20 PM
  #37
C3ForLife1968
Nah
To Looking for engine
Old Jun 4, 2019 | 12:28 PM
  #38
jackson's Avatar
jackson
JMO ... No it's Not good enough ... but Not because it has a cast crank (in itself, cast is good enough) ... but ... for the second time ...
... but ... because it's overpriced with heavily-worn bores & crap cam & crap heads. You can do much better with your $3300.
JMO ... A stock OE L31 Vortec will probably perform as well as (maybe even outperform) a stock OE L48/ZQ3 '69 300hp Base C3 motor.
FACT ... OE L31 is rated 255hp while loaded-up with all Accessories, Single Exhaust and Catalytic Converter ...
... quite different rating criteria-method than '69 vettes.
Yes, I understand '69 L48/ZQ3 Base 350 has 10.25:1 SCR while L31 350 has 9.4:1 SCR.
I'll also second the above gent's opinion that ... IF your shop/mechanic tells you bearings are bad, only because motor has 2 bolt mains ... run & find better help.
Old Jun 4, 2019 | 01:07 PM
  #39
C3ForLife1968
He is probably the best mechanic in my area. The 2 bolt i have is bad and has to be fixed by someone. I also need new pistons etc. In Norway this will cost the same as buying a new engine so that is what i will do. Sorry to tell you guys, but a 4 bolt is the only option for me, and Blueprint is known for thier quality. I think i will go for the engine i found if you cant find a dressed 4 bolt that is better
Old Jun 4, 2019 | 01:24 PM
  #40
jackson's Avatar
jackson
You'd best saddle-up and move pard
this is better https://www.summitracing.com/parts/nal-19367082
I'm done.
