Alternative front grills for a 71/72
As can be seen in the picture the front grills on my car are in poor condition. I can't justify the cost of a replacement and would like to fit something different like on this restomod, are those from a later c3? What will bolt on in place of the originals without much modification?
JMO ... perhaps this is the wrong project. Then again, might become a real show-stopper.
Good luck to the both of you.
Received 1,470 Likes
Cruise-In II Veteran
Dazaa Rafae Aman (06-05-2019)
Makes no sense to spend hundreds on a die cast grill which is easily broken and not easily replaced. Later C3 parts can be found relatively easy in the UK and I prefer the slanted grill to the egg crate 71/72 type. Originality means nothing to me on this project. I've found some 73 grills for a very good price, will they bolt in or are the mountings different?
do you know if the 68/69 grills use the same mountings as the 71?
2021 C2 of the Year Finalist - Unmodified
2017 C3 of Year Finalist
St. Jude Donor '13
Let me know if you're interested.
Stuart
Dazaa Rafae Aman (06-06-2019)
Here’s what I did with mine. I bought the L shaped grill mouldings and then got some black steel mesh and had custom grills made. Also made a matching piece for the centre.
I do have a set of 71 grills for sale in the classifieds as well.
There are lots of aftermarket polished aluminum horizontal bar truck grilles on Ebay. 50-60 bucks gets you enough to make 2 sets.
There are some small sheet metal brackets that hold in the 68/69 grills. Try a Corvette salvage yard if you need them. The plastic 68/69 grills are much cheaper to buy than the 70 and up cast aluminum alloy grills.
