Leaking gas from sending unit
Old Jul 7, 2019 | 02:49 PM
Peter G's Avatar
Peter G
Cruising
Default Leaking gas from sending unit
My’68 is leaking gas from the sending unit. I found that the locking collar was loose. I ordered new o rings. In replacing the o ring I found that the locking collar still would not hold the sending unit in place securely. The locking collar turns by hand and doesn’t compress the o ring for a tight seal. It would seem that I need a fatter o ring? Also, this gas tank was replace by the previous owner and all parts appear to be in new condition. Just continues to drip. Ideas?
Old Jul 7, 2019 | 05:09 PM
7T1vette's Avatar
7T1vette
You just have to find the easiest way to fix it.....
Old Jul 7, 2019 | 05:22 PM
MelWff's Avatar
MelWff
see your other thread for the answer
https://www.corvetteforum.com/forums...ding-unit.html
Old Jul 8, 2019 | 10:33 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Had the same problem with my 6t8, I used a narrow dull chisel to increase the height of the locking portion of the lock ring while suspending it over a small socket. T
To Leaking gas from sending unit
