Push Rod Rust
Old Sep 20, 2019 | 07:48 PM
  #41
Parzzival's Avatar
Parzzival
Originally Posted by HeadsU.P.
There is nothing in the photos that indicates you need a new engine. It does however, need lots of TLC.
The pitted cyl walls is cosmetic. That rust will not damage the pistons or rings. It will likely make this an oil burner though.
I would get this thing up on ramps. Drain the oil. I would then pull all the sparkplugs and introduce some 10W into each cyl. Use a funnel with a piece of rubber hose attached that will fit in the plug hole.
Put about four Qts of cheap oil in the pan and spin it over if it will. That would be a good start.
Worry about better oil and new plugs later.
Do you think it will not eat the rings? Ill definitely give it a try (no harm in trying). Ill give it a spin tomorrow. Its raining like a bitch in st. Louis now.
Also, I will be taking at least the number7 push rods out before trying it. The #7s are the only ones with rust and I don't want them to get jammed.
Old Sep 20, 2019 | 08:04 PM
  #42
HeadsU.P.'s Avatar
HeadsU.P.
At this point, you have nothing to lose except the cost of some oil.
You have a ton to gain by listening / looking at the shortblock for anything abnormal.
Cracked block, holes in pistons, broken rings, spun bearings, broken valves are all reasons for a new engine. You have none.
Yet.
Old Sep 21, 2019 | 04:31 PM
  #43
Parzzival's Avatar
Parzzival
Yet.
SOO I spent 2 hours wrestling off the valve covers. To who ever designed the break booster line, I will spit on your grave. 5 inches of steel line leading to a rubber line crimped on. After I did that, I got the spark plugs out and in the process found that the cross member has a BIT of a rust issue....
https://imgur.com/a/DIMjjPi
This is going from the middle of the car looking forward. The back of the cross member has rusted out. SOO my bird cage is fine based on what I can see from under the windshield. The side metal foot guard is fine. the frame under the car is fine. The rear end of the frame is FINE. But the stupid cross member rusted out... So at this stage whats my best bet? Take the engine out, weld in a new cross member (if I can find one) then throw the engine back in, hopefully after freeing it up.
Old Sep 21, 2019 | 05:01 PM
  #44
HeadsU.P.'s Avatar
HeadsU.P.
O-O-O-O- That's Bad! I mean real bad. All plans are off now. You would be way over your head trying to salvage the cross-member.
That's not normal. I believe that is from sitting in direct ground contact, flat tires, for decades just like you said.
Sorry. Parts car. Save your money.
Well, wait a minute.
What if the engine does spin over effortlessly?
What if you did pull the engine?
What if money was no object?
What if someone could weld on that . . . . . . . . . . . . .
Old Sep 21, 2019 | 05:37 PM
  #45
derekderek's Avatar
derekderek
If it can be made, it can be fixed. You want to save this car, first get the rain off the roof and get it on concrete or asphalt. Next THROW YOUR TIME BUDGET OUT THE WINDOW!! By the time this is roadworthy, you will be over 25 and much more insurable. Oil up and run the engine. See how bad it smokes. Buy 2 or 3 pushrods from parts store or a whole set on Ebay. They are cheap. If no spark buy a whole 50 buck distributor on Ebay. Any job you pay for will cost more than the tools. Get a good floor Jack and stands. When it is time to pull the engine 200 bucks for cherry picker or less used on craigslist. Assuming you have space for tools. If you fix it and give it to your sister, you are fixing it for free forever. You never fix cars for free for a woman you are not sleeping with.
Old Sep 21, 2019 | 05:51 PM
  #46
Duane4238's Avatar
Duane4238
Very good advice, but I wonder if Derek is married?
Duane
Old Sep 21, 2019 | 06:40 PM
  #47
HeadsU.P.'s Avatar
HeadsU.P.
Duane
I bet he fixes his mothers car.
Old Sep 21, 2019 | 07:27 PM
  #48
cv67's Avatar
cv67
St. Jude Donor '05
beats fixing Dads then LOL
Old Sep 21, 2019 | 07:49 PM
  #49
derekderek's Avatar
derekderek
Yes. I fix her kid's cars free. Only exception to that rule. Mom's car is a 2018 lease. She is 89 and never drives it anyway.
Old Sep 21, 2019 | 09:51 PM
  #50
Parzzival's Avatar
Parzzival
So i'm talking it out now with my sister. Assuming we decide to work on it, whats the whole process behind replacing this? Is there any sort of guide for this kind of thing? From what I see online, you would have to cut it off of a different frame, then some how line it up, and weld it on the old one. Or would it be better to just manufacture a cross member? Ether method would require taking at least the engine out. Possibly the whole front end.
Old Sep 21, 2019 | 10:13 PM
  #51
'75's Avatar
'75
You should read through this thread before you spend a dime on that bucket of rust.
https://www.corvetteforum.com/forums...-corvette.html
Old Sep 22, 2019 | 12:44 AM
  #52
Parzzival's Avatar
Parzzival
The main post was deleted. Is there a new one that actualy still exists?
Old Sep 22, 2019 | 07:01 AM
  #53
derekderek's Avatar
derekderek
go to last page and back up to post 107.
Old Sep 22, 2019 | 02:21 PM
  #54
Parzzival's Avatar
Parzzival
Oh I see it! Thanks!
Old Sep 22, 2019 | 05:54 PM
  #55
jackson's Avatar
jackson
Really? ... you have only $2K for this project ... motor's sick if not very sick ... frame's very sick ... Xmember repair/replacement requires welding skill & equipment ...
... should be done at a frame shop that has a frame table... from your description of situation, these waters are too deep for you/sister.
Perhaps each of you take a tail light lens as mementos; then sell car to a good home.
Get yourselves good educations and jobs ... and then you may buy a much better one or maybe even this one ... or new ones you can enjoy and pass to heirs.
I can imagine each of you'll will look right sporty in a brand new C9
Old Sep 22, 2019 | 06:20 PM
  #56
KenSny's Avatar
KenSny
No experience, no training, under estimate the cost, under estimate the damage. Take the $2k and toss it down the drain, get it over with now.
You think you can do it. BUT your comments and questions prove you don't have the knowledge to undertake this at all.
Sorry, it this sounds harsh. But someone here should say it instead of giving you false hope.
Good luck and move on from this disaster.
Old Sep 23, 2019 | 03:14 AM
  #57
Parzzival's Avatar
Parzzival
To everyone following this post and interested in this issue. Tonight I got the engine to spin over with no issue. I threw some oil in the cylinders and put a new battery in it. It turned over with no hesitation. Best part is that it didn't bend any of the valve train doing so! Now sadly we are probably going to end up selling it but we are still figuring all that out.
What will most likely happen is that it will get sold to someone who wants it as a project or it will get sold as a parts car. Ether way its one hell of a project car.
