Push Rod Rust
Old Sep 15, 2019 | 05:09 AM
Parzzival's Avatar
Parzzival
Default Push Rod Rust
Hello, I have a 78 that I am getting running after a period of about 20 years of sitting in the side yard of my dad's place. The valve covers rusted straight through. I have found no obvious rust on the valves (i'm sure the seats are destroyed) and the rockers seem fine. The issue lies on the push rods. They have major surface rust and possible rust pits. This is a car that I am kinda forced to sell once I get it fixed up due to the fact that I can't afford the insurance for it. What would be the best/cheapest rout here? Can I get away with taking the push rods out, polishing them, then putting them back? Or is it advisable, because I found rust there, to tear down the entire heads to polish and replace rusty parts? My biggest question here is, if I polish those push rods, can I get 100k miles out of them or is it worthless to try? Also, what is the worst case if i decide to polish and run these rods? I end up with a bent push rod? Because if the guides are already shot, ill need new heads anyway.
Old Sep 15, 2019 | 06:49 AM
SH-60B's Avatar
SH-60B
Price out new pushrods from Summit or similar place, they aren't that much $. With the rust on the pushrods, you might want to pull the intake and have a look at the valley and lifters. If that looks clean, go ahead and start it up to see how it runs. But, if you're going to sell it you don't need anything that's going to last 100K miles.
Edit: I saw a previous post you stated the hood had been left open for years, was the air cleaner on the carb? If not the rust you have found may be the tip of the iceberg. If it was up to me, and I couldn't afford it, I'd sell it as is.
Old Sep 15, 2019 | 09:46 AM
KenSny's Avatar
KenSny
Sitting open, hood up, valve covers rusted thru, rust. Count on water being in the cylinders.
Get out from under this quickly or spend money on an engine rebuild or a crate engine.
Then start to spend money on the interior, drive train, brake system locked up, etc.
And then, it's a 78, not a whole lot of value to recoup all the investment you could be spending.
Old Sep 15, 2019 | 09:57 AM
Fredtoo's Avatar
Fredtoo
Cut your losses, and sell it as is.
Old Sep 15, 2019 | 10:10 AM
derekderek's Avatar
derekderek
push rods are the least of your worries. if the engine rusted like that, the whole car is worse. this is a parts car. at best
Old Sep 15, 2019 | 10:30 AM
joewill's Avatar
joewill
yes, 20 years outside with x number of years with the hood up.. pushrods are the least of your worries and it is a big money pit.
from experience.. the entire car will be in such poor condition that you won't get back anything close to what you spend.
look at the market, you will see that poor condition late C3's sell for peanuts.
metal frames, metal floors and metal birdcages are the 1st to go, and the most expensive to fix.
if your valve covers are rusted thru, then it highly probable that all the other metal is toast.
Old Sep 15, 2019 | 10:41 AM
HeadsU.P.'s Avatar
HeadsU.P.
If you ever try to spin it over, you will do additional damage. I would bet that any cylinder with a valve propped open will hydro-lock if you crank it.
Old Sep 15, 2019 | 12:16 PM
7T1vette's Avatar
7T1vette
Sell it "as-is". Just advertise it with a legitimate photo. State the situation honestly and take the best offer you get. Someone will want it.
Old Sep 15, 2019 | 01:26 PM
cv67's Avatar
cv67
St. Jude Donor '05
x2 unfortunately the cyls are probably rusted to death too.
Can always charge up a 1299 GM crate at summit?
Old Sep 15, 2019 | 01:48 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Pictures are worth a thousand words as they say.
Old Sep 15, 2019 | 02:46 PM
Parzzival's Avatar
Parzzival
So I have no idea how many years the valve covers have been rusted through. But the hood up? No. The hood has been down for those 20 years. I will still be lubricating the cylinders before cranking and double checking for any water but it has not had direct water on the engine for that entire time. But I will take your advise and replace the push rods. Ill also check out the valley.
Old Sep 15, 2019 | 03:57 PM
KenSny's Avatar
KenSny
Well, push rod rust is indicitive of how much moisture got into the engine.
I seriously doubt if changing the pushrods and puting oil in the cyliders is going to solve your problems.
But, good luck anyway.
Old Sep 15, 2019 | 03:59 PM
derekderek's Avatar
derekderek
just pull the pushrods, rockers and spark plugs. oil up cyls and see if it turns. a big screwdriver on starter teeth may move it. Don't spend any money on parts. not until it spins. if it turns on the starter, tap each valve with a hammer. you will know if the valves are stuck or not.if motor spins and 16 valves open and close, you can think about pushrods. i betcha one or a few of us can scare up a few and ship them for price of postage.
Old Sep 15, 2019 | 04:12 PM
Old Man in a C's Avatar
Old Man in a C
Put it up for sale. Give an honest description and a realistic price (like free to a good home). You've ignored it for 20 years and now you want to cash in? Crazy. Don't waste your time and money.
Old Sep 15, 2019 | 05:00 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
Take it apart and see what you're actually working with.
Then decide.
Old Sep 15, 2019 | 06:22 PM
HeadsU.P.'s Avatar
HeadsU.P.
The O.P. never said it was his. Maybe he wasn't the one that ignored it. Maybe it was his dads. Maybe his dad just passed away. Who knows?
You don't know the situation.
No need for snarky, rude comments from A-holes.
If you don't want to help, ignore the post.
Old Sep 15, 2019 | 09:18 PM
7T1vette's Avatar
7T1vette
Whoever has it should NOT try to turn it over. Leave that to whoever buys it. You can do major damage to a rusty engine by simply attempting to make it rotate.
Again: Sell it AS-IS.
To Push Rod Rust
Old Sep 15, 2019 | 10:10 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
buy a cheap Harbor Freight Bore Scope with color monitor.....look into the cylinders....look into the oil pan through the oil drain hole...etc.
Post the pics for member's advice.
Old Sep 16, 2019 | 02:25 AM
Parzzival's Avatar
Parzzival
You nailed it on the head. My father passed last year. I'm getting it fixed up for my sister. I am only 21...
I read you loud and clear!! I had to buy a scope for opening the hood (stuck latch) so i'm already planning on running round the engine in every hole I can stick it in. I will keep people posted.
Old Sep 16, 2019 | 06:15 AM
Dazaa Rafae Aman's Avatar
Dazaa Rafae Aman
Nice to see another person on here around my age (I'm 24) i'd definitely post up some pictures of the whole car and close ups of the windshield surround to decide whether it's worth spending a penny on this car, if the valve covers are rusted through I can't imagine what the rest of the engine is like inside...
