C3 Brake System
Old Sep 15, 2019 | 09:08 PM
Anthony Salvo's Avatar
Anthony Salvo
8th Gear
Default C3 Brake System
I have a 73 Corvette Stingray that I bought from a private seller back in May 2019.. I've been doing some work to it on my own since I picked it up.. I replaced the brake lines from the master cylinder to each caliper, put BIlstien Shocks on it, installed brand new calipers and a few other things..
One recent issue after completing the brakes, i noticed the pedal takes full pressure to stop.. a red light appears on the dash in the speedometer area "Brakes" in red... yet the car comes to a stop no problem and my rear tail lights are not lighting up..
Ideas/suggestions?
Old Sep 16, 2019 | 12:14 PM
MelWff's Avatar
MelWff
Does the brake pedal go almost to the floor?
The light comes on because because the brake proportioning valve is sensing an imbalance between front and rear line pressure. https://willcoxcorvette.com/corvette...ng-valve-70-73
How did you go about bleeding the brake system after all those changes?
I now see you double posted
https://www.corvetteforum.com/forums...ke-system.html
Old Sep 16, 2019 | 03:34 PM
7T1vette's Avatar
7T1vette
Old Sep 17, 2019 | 07:26 AM
Anthony Salvo
8th Gear
this is a duplicate.. i will delete.. Thanks!
To C3 Brake System
