Tips for first rebuild
Rookie suggestions below:
If you really want to DIY the engine/if it doesn't "smoke-burn oil" you could leave the short block intact.
Replace the heads with new-improved heads.
Replace the intake manifold with a new aluminum manifold.
Install a new basic carburetor (non electronic) or install a Fuel Injection System with matching intake manifold.
Install new oil pump and new water pump.
Install new distributor
$2,500 +
New headers with true dual exhaust system or side-pipes ($500-$1,000 extra).
Keep us updated in this thread.
Good luck with your decision and let us know if we can assist in some way. Telling us your location might be a good start as some in your area might be willing to work with you on this project.
Best regards,
David Howard
AllVettes4Me
I would do a compresson check on all cylinders first and see what the rings and vavle seats are doing. If you have good compression you can leave the pistons, get a really good set of heads and throw a bigger cam in there and have a fun engine. Or pull the crank and pistons, give it a quick hone to clean the cylinders if they arent scored and just replace the rings.
You'll need a lot of new tools too...👍😁
Again, buy a small block rebuild book and do some reading first.
Rebuilding a good engine is alot easier than rebuilding one that got blown up.
Start with buying an aluminum intake, like an Edelbrock Performer. Simple installation, gives a bit of an updated look and a few extra hp.
If you get the feeling for it, then take it from there.
take your time follow directions ask lots of questions.Everyone has to pop their cherry!
Good machining+balance job youll be happy
Tampa Jerry has it right on, with the book suggestion. I have the same book and I also researched on YouTube and a myriad other sites on how to do this. BTW, my engine turned out great! It is a hard runner and I'm super happy with it. While you're at it, you might consider converting your engine from a bunch of noisy little belts and pulleys to a late 80's-early 90's serpentine belt system that were used on the C4 Corvettes with the L98 engine. This serpentine belt system is nearly a total bolt on. You do have to run a reverse rotation water pump, because of the belt routing.
Link: https://www.corvetteforum.com/forums...post1587817315
If you want to see an entire, blow-by-blow thread on my engine build, here it is:
https://www.corvetteforum.com/forums...ine-build.html
I used a late 80's-early 90's roller cam block. The GM 638 block, with provisions for a roller cam and a one piece rear seal on the crank (totally different crank from a pre-'86 block), but it fits in the C3, exactly like a regular 350. Whatever choice you make, good luck!
Just learn how to assemble it youll enjoy it
Torque wrench, feeler gauges, basic caliper kit...its not rocket science.
You can rent a balancer installer from an auto parts store or borrow one.
Most miss the fact youre looking for the experience not just the almighty dollar.
I dont want some hourly guy who hates his job slapping mine together I can screw it up myself for free! lol
The 1-2 man shops have gone the way of the dinosaur....cause cheap chinese crate motors guys foam at the mouth over.
I guess buying a crate takes out the possibility of him making the mistake but driving somehing you created vs wrote a check for is a different experience. Both good, one more satisfying...depending on what kind of time you got. bout the only crate Id trust (maybe) is a 572
After you have read it twice.....decide then if you want to proceed with doing the rebuild yourself.......as doggie said, it is not rocket science but the procedure is deliberate and precise....there are a LOT of things to remember and attention to detail is the order of the day. It is one of the most rewarding experiences in the world when you start it for the first time knowing you did it.
Jebby
https://www.amazon.com/How-Rebuild-Y.../dp/1557880298
Jebby
It is not easy, it can be stressful, as the fear of failure is big here. But, Jebby is right on. When you get in it, and crank it over, that's a feeling that can't be reproduced. That you built it, you didn't buy it. You heaved that heavy crankshaft, oh so carefully into the new bearings. You put in the pistons, making sure the rings were properly spaced, tapping them gently into the bores. You get to pick exactly what you want on it. ARP fasteners, Melling HVP oil pump, Milodon pan and so on. It's your baby!
2nd- don't invest a nickel into a 305 its a boat anchor,low power smog engine ( invest in a 350 with good heads, intake and fuel delivery system)
3rd - if you have the engine out have the trans serviced/flushed or freshened up because once you put some new power to it that will be the next thing to go.
on the other hand if you have the time, money and the energy to attempt the rebuild, go for it. It all depends on how long you want to look at your car sitting in your garage when you'd rather be out driving in it.
just my $0.02
