Fly wheel
Old Oct 11, 2019 | 09:54 AM
fake's Avatar
fake
Default Fly wheel
Where is the best place in CT (hartford area) to have a fly wheel turned?
Old Oct 11, 2019 | 09:02 PM
sunflower 1972's Avatar
sunflower 1972
Usually, any competent machine shop can resurface it.
Old Oct 12, 2019 | 09:07 AM
fake's Avatar
fake
I assume to true it up? Or should it be balanced also to any specification?
Old Oct 12, 2019 | 12:03 PM
derekderek's Avatar
derekderek
350? You can get it checked, but not necessary. Ext balance, leave it alone.
Old Oct 12, 2019 | 03:53 PM
jackson's Avatar
jackson
resurfacing grinds away micro-cracks & heat-spots also levels it ... any auto OR heavy-truck Machine shop
OE external balance flywheels' counterweights are on back of flywheel ... resurface those same as OE internal/neutral balance flywheels
Old Oct 13, 2019 | 10:19 AM
Tampa Jerry's Avatar
Tampa Jerry
While the flywheel is off, carefully check the starter or ring gear for chipped or rounded teeth. If suspect, change out the gear. They are easy to change at this point. Jerry
Old Oct 13, 2019 | 11:47 AM
fake's Avatar
fake
Thanks Jerry!
Old Oct 13, 2019 | 03:05 PM
SteveG75's Avatar
SteveG75
350 is internally balanced, not external.
For the OP, send an PM to Gary Ramadie (GTR1999). He is New Haven and should be able to tell you of a good local place.
Old Oct 13, 2019 | 07:00 PM
jackson's Avatar
jackson
OE 1-pc rms 350 (~86' - up) flexplate & flywheel has a counterweight but damper does not ... that began mid-run of C4 series ... lotta C3 these days have later blocks
OE C3 are 2-pc rms and true internal / neutral balance
Old Oct 13, 2019 | 10:27 PM
SteveG75's Avatar
SteveG75
Dang, forgot about the 1-piece rear main seal blocks. I have always had two piece seals. Of course, any engine can be internally balanced with the right amount of work. My 496 is internally balanced.
Old Oct 18, 2019 | 07:55 AM
fake's Avatar
fake
Thanks SteveG75, i did not know gary was in to fly wheels!
Old Oct 18, 2019 | 09:40 AM
SteveG75's Avatar
SteveG75
I doubt that he has the equipment to do them but I am sure he is dialed into the local machine shop network.
Old Oct 18, 2019 | 03:30 PM
GTR1999's Avatar
GTR1999
Hi Steve
I don't have a grinder for flywheels but I used Norlor Clutch in Hamden. I think they might have moved though since I had to have a clutch balanced and flywheel ground. They were good $30 to grind a flywheel and install a ring gear on it, now that was a while ago.
Old Oct 18, 2019 | 05:53 PM
SteveG75's Avatar
SteveG75
Originally Posted by GTR1999
Hi Steve
That is a good price. I just paid $80 here in Orlando for resurfacing and a ring gear (including cost of ring gear). Then, the new clutch was out of spec so another $20 to resurface again.
Old Oct 19, 2019 | 09:46 AM
GTR1999's Avatar
GTR1999
Well that was a long time ago during a period when automotive machine shops were common, grinding flywheels common, and the cost to do business in CT was under control. Your dollar was worth a lot more 15-20 years ago then today.
Our present and last governor killed manufacturing and the middle class by taxing them out of business or just by moving out of state. You were very smart to leave this area when you did. While I still love it here it's not getting any better and we really haven't recovered as much as other states since 2008.
Old Oct 19, 2019 | 02:55 PM
jackson's Avatar
jackson
Here's another reason ... you can buy a Brand NEW OE-type replacement flywheel with ring gear for $65 - $90.
Old Oct 22, 2019 | 07:24 AM
fake's Avatar
fake
Jackson where is that made China ? I like to an do support in Ct all residents who pay taxes.and own business. Thanks for your input. By the way were is it made and manufacture?
To Fly wheel
