Any Quick Jack Users?
Old Nov 25, 2019 | 02:31 PM
eddp's Avatar
eddp
Default Any Quick Jack Users?
Does anyone use the Quick Jack lift? The 5K that I looked at on the Home Depot site said max lift height is 17.5 inches. I'm not a thick guy, but when I set the yardstick up, it still doesn't give much room to move underneath, let alone on any kind of creeper.
Any user comments?
Old Nov 25, 2019 | 03:46 PM
C3_DH's Avatar
C3_DH
For some reason that doesn't sound right. I haven't put my C3 up on it yet, but I had my 66 Fastback up so high I was under it and saw things I never saw before it was so high up. Mine will definitely go higher than my heavy duty/tall jackstands will go. Mine is the 7K, it lifts my F150 high enough I sat on a roller stool and did the brakes without leaning over. Maybe you need the additional blocks / adapter kit?
Old Nov 25, 2019 | 03:52 PM
scottjamison's Avatar
scottjamison
Any user comments?
I love mine. It goes higher than 17". I think 17 is the first stop. I slide all around on a creeper under it.
It is super fast and really useful!
Old Nov 25, 2019 | 04:23 PM
How Are You's Avatar
How Are You
It's 21" with the blocks stacked. Edit...it's actually 22.5"
Old Nov 25, 2019 | 04:25 PM
scottjamison
I don't know if I would want to stack the blocks. You can see in the pic how I use them.
Whatever height it is, I find a ton of room under there.
Old Nov 25, 2019 | 06:59 PM
How Are You
Stacking the blocks isn't dangerous.
Old Nov 25, 2019 | 07:43 PM
BKbroiler's Avatar
BKbroiler
I have a 5K Quick Jack. The maximum lift is 18", not counting the blocks. I believe the thicker blocks are 3" so that makes 21" without stacking. That is quite a bit more than I get on jack stands.
Old Nov 25, 2019 | 08:33 PM
interpon's Avatar
interpon
Default Yes it is very dangerous
on my 79 frame rails where it gets jacked are not perfectly flat and when i double stacked it was very scary as they flung out..3 stayed and one hung in air..
read this...especially post 11 and 15!!
all that said happy with mine and 799 costco
https://www.corvetteforum.com/forums...21-2019-a.html
Old Nov 25, 2019 | 09:02 PM
C3_DH's Avatar
C3_DH
I also bought the truck adapter kit so I usually don't stack the rubber blocks. I love the thing, takes a little getting used to because of its weight, etc. but still a great thing to have in your garage.
Old Nov 25, 2019 | 09:05 PM
interpon's Avatar
interpon
ya no way stack them..
how big is that block you got and where?
Old Nov 25, 2019 | 09:16 PM
C3_DH's Avatar
C3_DH
https://www.quickjack.com/suv-truck-adapter-kit/
A bit pricey but solid as a rock.
Old Nov 25, 2019 | 11:57 PM
Devs77's Avatar
Devs77
I love my 5K QuickJack! I’ve had it for about a year and use it a lot. I haven’t had any problems stacking the blocks. I put my blocks in across the tray that they go in. I can see them squirting out if one were to put them in the tray lengthwise (facing the same direction as the lifts) but I tested mine by pushing, shoving and bumping into the car while it was on the lift and it was rock solid. I’d have to look at the manual, but I’m pretty sure it says that you can stack the blocks for additional height if needed. I get about 21” lift with mine.
Old Nov 26, 2019 | 05:39 AM
The Punisher's Avatar
The Punisher
Has anyone tried offsetting the blocks by having taller ones in the front? I did an oil change on my wife's Malibu and it didn't get all the oil out because of the angle
Old Nov 26, 2019 | 07:36 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Love my Quickjack, stacking the blocks has never been an issue for me, and I use it a lot.
Old Nov 26, 2019 | 07:51 AM
C3_DH's Avatar
C3_DH
There is no reason in the world why not - just make sure the car is solid once you get it up. Iif the car is tilted, I would think that far more dangerous than 2 different height blocks. I'm sure that is also why they give you different thicknesses instead of multiple of the same.
Old Nov 26, 2019 | 09:37 PM
Dirty Dalton's Avatar
Dirty Dalton
I have a wonderful Daughter! Takes longer to set up than a floor jack, but well worth the extra time.
Old Nov 26, 2019 | 11:29 PM
interpon's Avatar
interpon
Im just commenting on my experience stacking blocks..it only happened once, thats all it takes..again my frame rails as I’m sure many are not perfect flat...and if not perfectly parallel they will bind enough to toss blocks..just saying not arguing...
good luck be safe
To Any Quick Jack Users?
Old Nov 27, 2019 | 01:41 AM
jokeitch's Avatar
jokeitch
does the truck adapter kit get the extra height while being more stable than the blocks, though?
Old Dec 4, 2019 | 05:49 AM
C3_DH's Avatar
C3_DH
I can't really use the truck adapter kit on my 'vette, it is too tall to get under. Stacking the blocks are fine, I'd just take some extra time to make sure those blocks are square. Now that i type this, I think there might be something in the instructions that tell you not to stack them, but i'd have to look. I've stacked them (before I got my truck kit) and the vehicle was solid as a rock. I usually put a couple of jackstands under there too, haven't had the quickjack long enough to completely trust it... everything I read says you do not have to, but man, i'm ready to die, but just not under a car that I didn't stabilize, LOL.
Old Dec 4, 2019 | 06:14 AM
540 vette's Avatar
540 vette
I use these. Probably takes me the same amount of time to set them up. I can put them as high as I need them They keep the car on the suspension so I can take out the roofs and open the doors. I can do most anything under the car and have plenty of room and they cost me less than $60 to make.
