The silver tank next to the fender is your expansion tank. What the tank is next to the radiator, need a better pic.
There is no tank next to the radiator, he has an aluminum radiator.
The question is, is there a second pressure cap on the radiator?
If there is, and it is not a blank cap, the system is not correctly set up.
OK. I see it now. The, presumably, transmission cooler lines threw me. With the exception of my Avalanche, every car I have owned since 1983 has been a stick shift.
