Determine value?
Old Mar 5, 2020 | 11:25 AM
Punkchachi's Avatar
Punkchachi
Default Determine value?
Good morning!
I am new to this forum, so if this is going in the wrong place please let me know.
I am looking at buying an older corvette, 1975 Stingray Corvette 350 4 speed and I don't know how to determine if I am getting a good price. I asked for the VIN and am waiting for that. The description is,
"Chevy corvette with 350 engine 4 speed manual,car been sitting around 20 years. Tires have no miles on them,engine has around 8,000 miles , new rear bumper,carpet,battery cable. Has body damage around front headlights. Runs fine , needs brake work and leaking coolant around radiator. Make offer!"
So I randomly said $4000. He said that it would need to have smaller tires or to be lifted. Not sure if he put new, larger tires on but I am waiting for him to respond.
What questions should I make sure I ask and where can I go to attempt to price it/what do you all think this is worth?
Old Mar 5, 2020 | 11:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Careful here. $4000 may not buy much of a car and the description hints of problems. Can you post pics?
Old Mar 5, 2020 | 11:47 AM
vettebuyer6369's Avatar
vettebuyer6369
Originally Posted by Punkchachi
Good morning!
Assume you need tires. Assume you need a radiator and a brake job. Now the important thing: assume it needs body work at the nose and a paint job. From the cheapest estimate on a paint job to the more expensive, you have already surpassed the value of the car and you are in the red.
Obviously the car doesn’t have the original motor either. The final value of the car is going to be light. I’d say $3k, although I wouldn’t pay that either.
However, if your goal is to buy a Corvette as cheap as possible, drive and work on it as you go as a hobby and understand that you will be in the red no matter how you look at it, then try to get that number as low as possible and have at it. But don’t waste time thinking about tires or a brake job. Look very closely at the frame and birdcage for rust and look very closely at the body damage and determine if that collision affects other parts of the car and body panels. Those are the things that will sink your budget.
Old Mar 5, 2020 | 11:50 AM
Punkchachi's Avatar
Punkchachi
Added pictures!
Old Mar 5, 2020 | 12:47 PM
xpoc454's Avatar
xpoc454
From what you have mentioned i would guess around the $3000 range. I would also assume the tires are to old even with no miles on them they aren't safe to drive on.
Old Mar 5, 2020 | 01:16 PM
KenSny's Avatar
KenSny
You could seriously get into another $6000 in repairs. Maybe less if you can do the body work yourself. but still $4000 is a lot....
Old Mar 5, 2020 | 01:27 PM
60 SHARK's Avatar
60 SHARK
Yep,, hard pressed to spend 3k on this one,,,
Old Mar 5, 2020 | 01:29 PM
cv67's Avatar
cv67
St. Jude Donor '05
1500 is a stretch that cars going to need everything gone through it wont be easy or cheap
Cheap vettes can be the most expensive ones...for under 10k you can find a real nice driver.
Old Mar 5, 2020 | 01:50 PM
L-46man's Avatar
L-46man
Default Upside down before you buy it!
As you asked....Run, do not walk away. You are Upside-Down on the car and you haven't bought it yet!
Bodywork=$10,000
Suspension $2500
Interior= $3000
Engine drive train = who knows.
All this for a car that would be worth PERHAPS $7500 when it's done. Yes, It's a Corvette...so we feel you brother and we're happy . However 75's are the bottom feeders of the food chain....
I recently found a 76 for my neighbor.... Bright Yellow,.L-82 loaded auto, NEW interior, recent repaint, $2500 worth of tubular suspension, nice wheels and tires, etc ,etc, $7500 including tax.
See what I mean.....let this one go....it's a rolling parts car!
There is absolutely NOTHING on this car that is compelling.....
KEEP LOOKING!
Unkahal
Old Mar 5, 2020 | 01:52 PM
Aggitated Monkey's Avatar
Aggitated Monkey
All depends on what your looking for and to do with it. If you want a builder that your going to go through and make it what you want I think that car may be fight. If you want a driver that you can easily maintain and keep clean for little $; this is not the car. You will
be in the $10 to $15 k for a reasonable driver. If yo want more then that and you want a nice to perfect car with little to no restoration it will go up from their.
Old Mar 5, 2020 | 01:54 PM
KenSny's Avatar
KenSny
Unkahal
I'm pretty sure I take offense at this.....
Old Mar 5, 2020 | 01:59 PM
Bikespace's Avatar
Bikespace
Honestly, $4K for that car is about $4K too much. Even doing the work yourself, you could easily spend $5K just getting the brakes, suspension, and interior squared away. What does the engine look like?
You will never come out ahead, even if you do the bodywork and paint yourself (needs a new front clip or a serious repair). And who knows what the rust situation is. If it has been sitting outside with the cracked T-tops I see, it is possible that the entire window frame is held together with chrome trim, and the front of the birdcage is rusted out.
That said, it is a white 4-speed, the best kind of C3 to have. The wheels look good (tires need to be replaced immediately, of course). There are folks on this Forum who have adopted and rescued worse cars, but this one needs a LOT of work, and that is assuming the birdcage is intact.
Read post 107 here:
https://www.corvetteforum.com/forums...orvette-6.html
Old Mar 5, 2020 | 02:24 PM
L-46man's Avatar
L-46man
Default Sorry Ken
Sorry Ken I recuse myself!....1. I meant 84's LOL 2. I would be VERY happy to be driving a 75...knowing WHAT IT IS. 3. It is still an actual STINGRAY. 4. I probably should have said something like, "the bottom of the Value/performance curve".....jeez....let me stop digging already!
No insult intended. Truly.
Unkahal.
Old Mar 5, 2020 | 06:12 PM
Stev-o's Avatar
Stev-o
+1 ... keep looking. That car has been neglected and/or abused.
"The cheapest cars become the most expensive cars".
Up your budget and find a nice one. Good Luck
Old Mar 6, 2020 | 07:24 AM
Punkchachi's Avatar
Punkchachi
Default Thanks y’all
I have asked him more questions since reading yours responses. He was vague and stopped responding. Thanks for the help! Any suggestions on where I can find a corvette? I enjoy working on cars and I am not looking to sell it for a profit, I would like to put work into it so I can make it mine. I have always wanted to own one since I was a kid.
Old Mar 6, 2020 | 07:54 AM
Bikespace's Avatar
Bikespace
If you could get it for parts car money ($1K or so), it would be a fine parts car.
Are you in Virginia? I found both of my Vettes from private sellers on Craigslist. Search nearby cities in neighboring states, too. There are sites that can help you search Craigslist by region. Other websites exist, but are more likely to find a car at a dealer, who will mark up any car by $5K just for sitting on their lot.
Good luck!
Old Mar 6, 2020 | 07:16 PM
stingr69's Avatar
stingr69
That is a parts car. You need a better core.
To Determine value?
Old Mar 6, 2020 | 07:27 PM
topcarbon's Avatar
topcarbon
2020 C3 of the Year Winner- Unmodified
That log is going to keep you warm at night after your significant other leaves because you are so far upside down on this car
i would burn the car before that log
Old Mar 11, 2020 | 04:40 PM
Punkchachi's Avatar
Punkchachi
Just as an update, I still have not heard back from him but he updated the listing and it is now $2500
Old Mar 11, 2020 | 07:04 PM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
[QUOTE=vettebuyer6369;1601068872]...
... understand that you will be in the red no matter how you look at it, .../QUOTE]
Ouch
