Leaf blower for drying ?
Old Mar 28, 2020 | 07:36 PM
tutermoe's Avatar
tutermoe
Default Leaf blower for drying ?
I know some won’t with expensive paint jobs, but mine has 6 foot paint job 😉
Old Mar 28, 2020 | 07:41 PM
interpon's Avatar
interpon
Yes its fine..electric anyway...not sure i would use a commercial gas
Old Mar 28, 2020 | 09:27 PM
kansas123's Avatar
kansas123
I have used one a time or two. I believe someone actually makes a hand-held device just for the purpose of drying the car....
Old Mar 28, 2020 | 09:38 PM
Bikespace's Avatar
Bikespace
While you're at it, use it to blow the dirt out of the garage (hold your breath, or wear a mask).
Actually, do this BEFORE you wash the car. Ask me how I know...
Old Mar 29, 2020 | 06:50 AM
pigfarmer's Avatar
pigfarmer
I use a small electric leaf blower on my bike - a million nooks and crannies in there to get water out of.16 years later it hasn't caused any problems.
If you're worried there are electric blowers intended for cars with big name sponsors that cost ten times as much.
Old Mar 29, 2020 | 07:28 AM
nutsy's Avatar
nutsy
I use my gas one on mine all the time. works great to get the water out of areas like the back lights and so on. otherwise if you wash it and put it back in garage the water sits there where you cant see it and the less water on my car the better.
Old Mar 29, 2020 | 07:31 AM
Vinnievega's Avatar
Vinnievega
Totally fine, and recommended over using any sort of towel / chamois. I have the rigid wet vac that turns into a leaf blower.
Old Mar 29, 2020 | 08:04 AM
gbvette62's Avatar
gbvette62
I've never used a leaf blower to dry my cars, but a neighbor regularly dries his 76 with one.
I just spent a month in Florida, and while there I took my truck to a car wash in Cape Coral. At the drying station at the exit of the car wash, they had air hoses with blow guns, and went around each car blowing water out of all of the body lines, emblems, nooks, crannies and crevices. I've done this myself at home, but have never been to a car wash that did that.
Old Mar 29, 2020 | 09:07 AM
pigfarmer's Avatar
pigfarmer
Well, anybody needs an inexpensive electric blower I bought one of these last year:
Amazon Amazon
It has a rheostat you can turn the power way down with and when you turn it up hang on to the damned thing. Not kidding about that.
Home Depot actually gave me the best price on it. .
Old Mar 29, 2020 | 09:26 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Old Mar 29, 2020 | 09:30 AM
MAD IN NC's Avatar
MAD IN NC
Crowd Plow For Now
I use a Still Magnum 600. 200 MPH
Old Mar 29, 2020 | 04:21 PM
7T1vette's Avatar
7T1vette
Depends on how you've used that blower before. If it has had any 'junk' go thru it (dirt, sticks, etc), I wouldn't use it to dry my car. If you know that the inside has always been clean, go for it.
Old Mar 29, 2020 | 04:38 PM
Tiger Joe's Avatar
Tiger Joe
Have used a gas leaf blower for years to dry cars. Never had an issue
Old Mar 29, 2020 | 04:52 PM
Redvette2's Avatar
Redvette2
If electric...might suggest to make sure it is plugged into a ground fault circuit interrupter (GFI) receptacle for safety if there is still water on the ground.
71 Vert LS1's Avatar
71 Vert LS1
I typically use the air hose off my air compressor for the tight spots. Use super soft used old bath towels on the rest of the car.
Old Mar 29, 2020 | 05:11 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I use my gas sthil blower on my 66 Chevelle all the time. its the easiest way to get all of dry with all the trim thats on the car
Old Mar 29, 2020 | 05:27 PM
BLUE1972's Avatar
BLUE1972
Any leaf blower that does not crunch up leaves.
I use the small Milwaukee M18 blower, It works very well and is portable, takes the M18 batteries that my tools use.
When my friend passed I wound up with the expensive one that the car / Wayne Carini shows push. I see no difference - except the expensive one is 115 volts and has a cord.
To Leaf blower for drying ?
Old Mar 29, 2020 | 08:05 PM
stingr69's Avatar
stingr69
Works great. Doesnt everyone do it?
kdf1986's Avatar
kdf1986
I dont see a problem using the leaf blower. I use my air compressor to blow out the water around the emblems, tail lights and other trim.
kdf
Old Mar 29, 2020 | 10:30 PM
Mark G's Avatar
Mark G
My concern is somewhere between now and the 20th wash, somehow I would accidentally 'whack it' with the tip and put a big scratch on it. Seems like everytime I get a 'bright idea' it ends up costing me something in the end ...LOL.
So, use extreme care.
