C3 1981 LED Bulbs
Old Mar 31, 2020 | 12:03 AM
TO_Vette's Avatar
TO_Vette
Default C3 1981 LED Bulbs
Getting ready to replace the board on my tach and figured I would replace the bulbs. Do you know the part number and where I can get a set of dimmable led bulbs?
Old Apr 1, 2020 | 10:03 AM
TO_Vette's Avatar
TO_Vette
Nobody has every done this?
Old Apr 1, 2020 | 10:48 AM
Theman5's Avatar
Theman5
I ordered some individual 12v LEDs off amazon for a steering wheel lightning fix on an Envoy. They operate over a range of voltage so some dimming available. Lots of different colors available.
Like a 100 for $15
Old Apr 1, 2020 | 05:04 PM
SwampeastMike's Avatar
SwampeastMike
Here's one. While it is dimmable note that the operating range is 10V-30V so you can't expect much dimming range. Also I don't believe that the simple rheostats in our headlamp switches are well suited to dimming any LED. Also know that when LEDs dim the color of their light stays the same while when incandescents dim it becomes more yellow/orange. This means you'll never get that nice soft green glow that the cluster and gauges are supposed to produce.
In my opinion LEDs aren't suited to older cars as they aren't designed to work with their fixtures or their electrical systems. Exceptions are indicator/warning lights--be certain to use an LED the same color as the lens--dome lights, courtesy lights, glove box lights, underhood lights, etc.
Also be aware that LEDs are incompatible with the front turn/park/marker lamp circuit unless you do extensive rewiring. Why? In some situations some of the lamps get their ground via the filaments of the non-illuminated lamps in the circuit. Such a pathway does not exist with LEDs.
Old Apr 2, 2020 | 12:25 AM
7T1vette's Avatar
7T1vette
Proper dimming is only achieved by two methods:
1. a pulse-width modulating (PWM) device that is used to adjust for all LED bulbs in a 'string';
2. bulbs that have PWM circuits built into them so they operate normally with a regulated DC system.
A PWM module is very inexpensive. But finding good quality LED bulbs that fit properly in C3 (GM) sockets is not that easy. Most (if not all) of the cheap LED bulbs are JUNK!!
Old Apr 2, 2020 | 01:44 AM
Lakeside49's Avatar
Lakeside49
As a friendly FYI, this nearly identical question was very recently posted - and, very frequently comes up. Do a quick search for LED bulbs and you will be pleasantly overwhelmed with insights.
Old Apr 2, 2020 | 09:13 AM
Theman5's Avatar
Theman5
What ever route you take you might end up experimenting a lot. Bulbs not bright enough, to big for application and short life span.
I put some red LED in climate control and had to basically modify the base of the LED as they were too long for the slot. Also side emitting would have been better than the end emitting ones I found.
Old Apr 2, 2020 | 04:46 PM
7T1vette's Avatar
7T1vette
The simplest (and least expensive) approach is to install stock incandescent bulbs. They will last many years before they lose brightness and the dimming feature will work just fine.
I like the idea of long lasting, bright bulbs with very little current draw, too. But I haven't found a reliable way to get that done.
Old Apr 2, 2020 | 05:35 PM
SwampeastMike
That's why I've installed hundreds of them in my pinball machines in all of the shielded (scoring/indicating) lamps. As my newest machine is about 15 years old (before LEDs were common) I still use incandescent lamps for all of the general illumination as the LEDs are far too bright and glaring to my eyes.
As '71vette said, incandescent indicator and dash illumination lamps last many years in automotive applications.
Old Apr 2, 2020 | 09:50 PM
Theman5's Avatar
Theman5
but you don’t get the different color options you have with LEDs
Old Apr 4, 2020 | 11:55 AM
Street Rat's Avatar
Street Rat
I wrote a rather lengthy review of my led light install on my '81. It is complete with the part numbers and sources. Search for it and I'll try to find it too.
Craig
Old Apr 5, 2020 | 07:08 AM
Street Rat's Avatar
Street Rat
Default Thread on Leds
Craig
https://www.corvetteforum.com/forums...at-fits-2.html
Post #39
Old Apr 6, 2020 | 09:41 AM
Corvettestan2's Avatar
Corvettestan2
Cruising
Default LEDs for dash
Hard to capture in a picture but I love my new bright white LEDs that I installed. I never tried to dim them but I don't know why you would. I coated the back buckets with shiny aluminum to make it even brighter and lass green as well
To C3 1981 LED Bulbs
