Question about '72 brake pulling
Old Jun 13, 2020 | 09:07 AM
paulebrown's Avatar
paulebrown
Default Question about '72 brake pulling
When I brake on my 72 the steering wheel pulls abruptly left. Is there an adjustment on the brake. I've never done any brake work.
Old Jun 13, 2020 | 09:15 AM
Mooser's Avatar
Mooser
There's no real adjustment for that but something is wrong with one side or the other
Start by putting the front up on stands, spin the wheels by hand and have someone press the brakes (car doesn't need to be running) and see of the passenger side even works
Check the pads/rotors for being worn out / grooved up, etc. Does the rotor on the passenger side seem clean, use a mirror to look at the back side as well. These don't have floating calipers so inside and outside are independant
If everything looks ok and seems to move when you step on the brake, bleed the system, might be air in the line to the passenger side (brakes should feel spongy though...)
M
Old Jun 13, 2020 | 09:18 AM
paulebrown's Avatar
paulebrown
Thanks for the response. That will be my project for today.
Old Jun 13, 2020 | 09:25 AM
Old Man in a C's Avatar
Old Man in a C
More often than not, if it pulls to one side, the problem is the opposite brake.
Old Jun 13, 2020 | 05:48 PM
69lemans's Avatar
69lemans
This ^^^^^^
May want to try and bleed the passenger side caliper. Should probably bleed all 4 corners while you are at it.
Old Jun 13, 2020 | 06:43 PM
Tampa Jerry's Avatar
Tampa Jerry
Check for a leaky caliper on the opposite side of the drag. Also check and or replace the rubber brake hoses if over 7-10 years old. Jerry
Old Jun 13, 2020 | 11:40 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
An underinflated tire (like 10 or more lbs under) can also cause pulling, though opposite of a brake problem - meaning the low tire would be the front left.
Old Jun 14, 2020 | 09:09 AM
paulebrown's Avatar
paulebrown
Thanks for the advice. The brake works both sides, tires are inflated properly. Now to check the calipers. Don't really know what I'm looking for.
Old Jun 14, 2020 | 10:06 AM
Mooser's Avatar
Mooser
Brake pedal doesn't feel spongy right? if it does you might have air in the lines and it need bleeding
Visual inspection
Either the drivers side is grabbing too much or the passenger side isn't grabbing enough
Scored up rotors, really smooth (polished) rotors, worn or glazed pads
Make sure you use a mirror and look at both sides.
Car is safely on stands (not harbor freight ones...)
With the wheels off you can have someone apply the brakes and make sure you see the inside and outside pads moving (not much room to move but if you look close you should be able to see them)
You can remove the pads by taking out the pin in the middle of the top of the caliper BUT they are sometimes a bit of a pain to get out and back in and whatever you do - don't touch the brakes if the pads are out!
M
Old Jun 14, 2020 | 11:00 AM
paulebrown's Avatar
paulebrown
Visual inspection
M
All good advice. Thank you. I was 36 years old when I bought this car (new) in 1972. There are some things I can handle, some I've learned not to get in over my head. So will take it to a nearby service to decide how to deal with it.
pb
Old Jun 15, 2020 | 01:56 AM
Giddy-up Go's Avatar
Giddy-up Go
I would guess a broke hose collapsing. I would replace both hoses (if one is bad won't be long til the other is) and bleed brakes.Would check that before calipers.
To Question about '72 brake pulling
