72 indicator timing rate
Old Jul 29, 2020 | 08:55 PM
72downunder's Avatar
72downunder
Default 72 indicator timing rate
Hey Guys
my left (drivers ) side indicators operate at a slower rate, really slow, than the right (passenger) side. All bulbs are fine and turn on, is it a relay issue? As in I need to replace both relays to get them to operate at the same switch on/off rate?
or maybe something else?
Old Jul 29, 2020 | 09:37 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by 72downunder
Hey Guys
Same relay. You have some socket corrosion or lamps not up to snuff.
Old Jul 29, 2020 | 10:16 PM
72downunder
Thanks, I’ll have a look.
where would the relay be located so I can clean the connectors on that as well
Old Jul 29, 2020 | 10:35 PM
MelWff's Avatar
MelWff
There is one flasher in the fuse box and another behind the passenger side dash accessible by looking under it. One is for the signals and the other for 4 way, dont remember which is which.
Old Jul 30, 2020 | 06:36 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
the one under the dash is for signals..I would suspect a bad gorund. If I remeber correctly, when a bulb burns out they hyper flash on that side. You defintely have to check for bulb corrosion in the socket like the Bird said. I would push in your hazards button and see what happens as well
Old Jul 30, 2020 | 08:10 AM
7T1vette's Avatar
7T1vette
Could one of those bulbs [on the 'slow' side] have been changed to an LED bulb? If so, the current load on that side would be much less and would cause a stock flasher module to operate at 1/2 the flash rate.
Old Jul 30, 2020 | 06:27 PM
72downunder
All bulbs are old school, no leds
thanks for the info will check it out this weekend
Old Jul 30, 2020 | 08:28 PM
BarryB72's Avatar
BarryB72
You can get the flasher that goes under the passenger dash at auto zone for like $5.
Might be the quickest way to eliminate something from the list.
Old Jul 30, 2020 | 09:17 PM
Peterbuilt's Avatar
Peterbuilt
My guess is that you have corrosion inside the plastic socket.
To Test the socket attach a wire to a good ground and touch the other end to the brass part of the bulb holder.
If the bulb lights up properly you found the problem.
To 72 indicator timing rate
