Door Panel Tips, Please!
1. Does the plastic water shield under the panels go over the connecting rods for the door locks or under them?
2. I bought the set of screws for the interior, but which screws are the ones for the door? I thought the labeling would be better.
3. Any tips on how to put the screw through the right location in the panel to hit the hole in the door without multiple tries?
Thanks!
Thanks!
The panels are mounted with sheet metal screws. These screws usually screw into a fastiner variously called a "tinnerman," U-clip, or speed clip.
https://www.belmetric.com/index.php?...s8h7hjskkj0gq6
Since the tinnerman clips can move around, you may not be able to get the screw to engage in the clip hole. With the panel pulled back about an inch, insert a long thin pointed object through the panel empty screw hole and use a pick or a very thin screwdriver to engage the hole in the tinnerman clip and move it in position for the screw you're intending to use.
The panel is plastic(instead of original fiberboard) with a foam core, and vinyl skin.
I lined up the trim and marked where the holes would be. I drilled theback just enough to pierce the plastic.
I used and awl/ice pick and pushed it through the hole as straight as possible thru the foam core.
Slowly, til it starts to press the vinyl skin. you will see where it is pressing up thru the panel(without piercing the skin, yet)
You can see how far off your mark it is.
Adjust the awl to the marks you made and pierce thru. (just a small hole, its for reference. dont size it up yet, if its off you can live with a pinhole instead of a larger drilled hole)
do the same for the rest of the trim.
Hold the trim to the panel and see if they line up correctly.
If all looks good, use a drill proper size of trim and enlarge the awl hole.
P.S. What do you have to lose by trying it??
For what it's worth, if you mean the one in the corners..
I never installed the screws through the door panel, only used the two clips that go around and onto the side of the door. Between those and the door pull screws it's actually fairly tight and has never rattled or anything. It's only been 20 years or so but maybe it'll fall off tomorrow
M
First, look at door photos and see where the screws go for a generalized idea. Al Knoch door panels have light oval scars on the reverse side of the black plastic panel molds, take a small screw and slowly run it through the door panel in the center of this mark until you can just barely see it or feel it just behind the vinyl face of the door panel. Reverse the screw and recheck the alignment. Before you break the surface of the vinyl, mount the door panel using the factory clips and the factory plastic press together Velcro (in similarity) pieces. Holding the panel tight and in the best correct spot you can get (you might need another pair of hands) make witness marks on the back of door around the perimeter of your panel. If need be, because of shape or contact problems, set the panels in the sun or carefully use a heat gun set on the lowest setting and wave it no closer than 6” to 8” above the surface at a pace a little faster than you would spray painting that panel. Using clean gloves remount the panel using your witness markings. You should be ready to run your screws through the panel into the door, and don’t worry, there’s plenty of steel behind that screw area. Stand back and admire your professional workmanship. Note* the factory had dimpled holes on the face side of the panels and dash sections and recessed washers. It’s your choice, but know you will take a hit on judging if washers are missing (see photos for all panel mounting hardware).
Ok, I saved the best for last. Velcro makes a heavy duty, 2 part in tape form rolls - $15 for 25’ found at most good hardware stores. Follow the same directions as above, but skip the “screws” part. This heavy duty velcro tape can be placed an inch or so back from the panel edges in 2” to 4” strips around the sides and bottom edge. Remember about NCRS correctness, if applicable. It’s up to how well the panel follows the contours of the door to determine how much Velcro to use. This stuff can really hold parts and the adhesive is HD as
If you have any problems you know where to find me.
Rich
Rich
My panel from Corvette America is thick all the was to the end, where the pictures posted of other's seem to have a thinner edge,
