I have owned my Vette since new.. However the AC system quit working. I took it to a shop and they reloaded it with Freon (the original coolant) and it worked for a day or so then the compressor (the original compressor) quit working.
I would like to keep the car as original as practical.
What would be the recommendations here. Should I purchase a rebuilt compressor compatable with the newer R134a coolant? Or should I have someone rebuild my original compressor?
What would be the suggestions here. I'm not sure I want to go with the original coolant although it would probably cool better than the R134a.
Is there such a thing as brand new A6 compressors compatable with R134a?
Are you sure the compressor is not operating. See if the hub clutch (very front with rubber) turns with engine running and A/C on. If so it's most likely not the compressor, but low on freon. If it does not turn there may be a pressure switch that cuts off the power to the clutch if freon is low. Sounds like your switches to turn the system on worked.The compressors are well built and do not break. They will sling oil at the clutch when in need of overhaul. Now with engine off, see if you can turn that very front (with rubber) hub clutch by hand. It will not turn easy but see if it turns. If it does then compressor should be good and again low on freon.
All that done then you need to work on the system and check for leaks. I don't remember when the low freon switch was installed but there is someone here that does.
Dom
ballen06
My 1969 a/c system does not have a low pressure switch that I can find. Pretty sure it does not have one.
Your accumulator should have a sight glass on top. With engine running have someone turn on the a/c while you watch the sight glass. There should be a rush of bubbles followed by clearing of bubbles if you have a decent amount of R12 in the system. I bet your compressor is fine, just needs resealing including a new shaft seal. (not difficult) Maybe new expansion valve, too.
Forgot to mention Old Air sells a new version of the A6. It reportedly works well and is compatible with R12 and 134a. Probably comes with PAG oil in it so would need to flush that out if sticking with R12. I would buy one if my original A6 ever fails (and stick with R12.)
BTW- Dom is a very wise A/C man.
morning
I am certain you have a sight glass. It sits on top of the accumulator. It is easily observed by opening your hood and looking down by the passenger side in front of the headlight. You will see a small refrigerant line going into the top of the accumulator and another coming out. The round glass in between is the sight glass.
Thanks .. I did your tests and it indicates that I am low on Freon. If that is the case then I have lost $575 dollars worth of R12.
Great!
Are leaks hard to find?
You paid someone $575 to recharge your system and they didn't perform a leak check? There is very little demand for R12 these days and I usually buy cans of it off Craigslist for $15 to $20 each. $100 per lb retail would be more than fair, so the extra $200+ you paid should have gone towards finding and repairing any leaks. Hopefully they didn't double screw you by putting in R12 "replacement" garbage. I'd take it back, and if they don't make good, hopefully you paid by CC and can do a charge back.
Since it leaked out within a day, the leak won't be hard to find. If you're in a quiet garage and have good hearing, you'd probably hear it hissing. Any decent shop would pressurize the system with dry nitrogen and a trace amount of refrigerant and then go over it with an electronic detector. My best detector can locate a leak that loses 1/10 of an ounce over a year's time.
Common area is the compressor seal, you may even see oil behind the pulley. The rubber hose set on my '75 became very porous after 35 years. Fortunately there was an AC Delco replacement being made again around 2010 and it was very cheap, about $100.
After 51 years, any rubber hoses and seals should be replaced on your system.
If you are sure your compressor is kicking on and the sight glass shows no bubbles I would say your system is empty. Dont run the compressor with an empty system.
I would do as vairexpert suggests and take it back to the guy that charged you $575!!!!
Take your car to a shop that is reputable and skilled in auto A/C work. If you don't know any shops like that, ask around at the next local car show. The shop name that comes up most often is the place to go.
Another alternative is to convert your present system over to 134a and a new Sanden compressor. ClassicAutoAir has Corvette-specific kits for each model year and engine combo. Total cost is not much more than what you paid for just filling with R-12. Cans of 134a are about $5 at Wal-Mart. Something to think about for the 'long-haul'.
If you are not diy...and you are going to pay someone else...
find someone who is reputable and offers warranty...
R12 diy craigslist ebay is less than 100 bucks diy..and thats being conservative...
take it back first...
if you are doing any diy get gauges...and read pressures
