T Top repairs
Old Sep 12, 2020 | 04:03 PM
Corpor's Avatar
Corpor
Default T Top repairs
Does anyone know who sells a compact electric hand saw, like carving knife size? Also looking for a windshield pillar weatherstrip video on the "way" to manipulate the new molding into place.
Old Sep 12, 2020 | 04:10 PM
ignatz's Avatar
ignatz
As seen on TV
Old Sep 12, 2020 | 05:39 PM
Corpor's Avatar
Corpor
Well, I want one of those now, but that won't do what is needed. I need to reach the velcro fastener with a blade, a few inches in between the headliner piece and the T-Top outside piece. Somebody repaired them with way to much epoxy. They put globs of it between the 2 velcro fasteners, so I figure cut between them through the epoxy sandwich to get it apart,.
Old Sep 12, 2020 | 06:09 PM
interpon's Avatar
interpon
One of the most versatile powerful for its size tool i have takes any blade and when done will cut a small tree
https://www.lowes.com/pd/Bosch-12-Vo...cluded/4757515
or larger electric and cheaper..that looks like silicone to me not epoxy...if epoxy good luck..try a metal blade..otherwise silicone will cut with a knife
Old Sep 12, 2020 | 06:25 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
oscillating saw?
https://smile.amazon.com/PORTER-PCC7...949427&sr=8-10
Old Sep 12, 2020 | 11:15 PM
Corpor's Avatar
Corpor
Perfect!!!!! Just bought it, what about the blade?
Old Sep 13, 2020 | 12:08 AM
barkingrats
What are the characteristics of the material you're looking to cut? Soft and rubbery, or hard and solid? Soft/rubbery likely would do better with a knife-like blade. Hard/solid a saw-like blade, maybe 10-12-tooth/inch -ish.
Old Sep 13, 2020 | 12:14 AM
Corpor's Avatar
Corpor
Cutting through epoxied velcro fasteners of the T Top.
Old Sep 13, 2020 | 07:20 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
To get in there and cut through the glue, have you tryed an electric carving knife? It's serrated edge's should be just the ticket.
Old Sep 13, 2020 | 01:50 PM
barkingrats
Epoxy will soften with heat. Try a heat gun to warm it to about 150° and see if you can gently pry it free with a putty knife. Go easy on the heat as you don't want to bubble surrounding or back side paint.
Old Sep 13, 2020 | 04:21 PM
Corpor's Avatar
Corpor
Bought one of these shared by interpon. Can't wait to use it, small and fits in your hand nice. Got one with the blade and battery for $99. at Lowes.
Old Sep 14, 2020 | 11:48 AM
7T1vette's Avatar
7T1vette
What are you attempting to do? I know you want to remove the panels from the T-tops...but why? There may be an easier way to resolve the actual problem you are trying to solve.
To T Top repairs
