1976 horn
Old Sep 28, 2020 | 12:07 PM
Gooseneck64's Avatar
Gooseneck64
2nd Gear
Default 1976 horn
I purchased this 1976 Vette and want to get horn working. I have upper horn out completely. Pin and spring everything! I hooked up a new horn. 2 post horn. I got one going to the original ground and when I go to plug in other terminal the horn sounds off. I’m baffled because horn button is out. I installed a new relay also. Is this something in deeper on steering column? It is tilt and telescoping.
Old Sep 28, 2020 | 04:50 PM
bmotojoe's Avatar
bmotojoe
Your horn relay (RED WIRE) has power to it at all times, horn relay contacts are normally open.
The ground path to relay coil is made when you press the horn button.
Once the relay coil is energized the relay contacts close and the horns should work through the DK.Green wires.
I don't know what original ground you are hooking up to the new horn as the originals when bolted to the chassis is the horn ground.
If your horn is blowing the relay coil has energized and the contacts of the horn relay have closed.
Make sure at the horn button there is nothing grounded in that area.
Post a photo of the new horn posts and of the dissembled horn button area.
Old Sep 29, 2020 | 12:07 PM
Gooseneck64
2nd Gear
Default 76 horn constantly blowing
I have the one post grounded to where the bolt is normally located and other to hot wire . I found that when I move the steering wheel in and out is when the horn blows when it’s half way in. I’m assuming the lower spring in shot?
i hope this helps I’m new to this forum stuff
To 1976 horn
