The Impossible Blower Switch Problem Challenge !
Old Oct 8, 2020 | 12:43 PM
yelo80vette's Avatar
yelo80vette
Default The Impossible Blower Switch Problem Challenge !
So last year the blower switch in my 1980 stopped working. I replaced the blower motor . . . nothing. I tested the switch . . . switch is good. Fuses . . . ? Fuses okay. Wiring? looks fine. Can anyone please tell me how, from beginning to end, to start to trace and find what is causing this problem? Eternal thanks.
Old Oct 8, 2020 | 01:01 PM
Greg's Avatar
Greg
Just another Corvette guy
Did it stop blowing on all settings, High, Medium and Low?
I would check the blower relay.
Old Oct 8, 2020 | 01:40 PM
yelo80vette
Yes, on all settings so it's not the relay.
Old Oct 8, 2020 | 01:47 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Do you have a 80 GM service manual? It has all the diagrams in it that you need to troubleshoot this issue. GL
Old Oct 8, 2020 | 01:50 PM
walleyfisher's Avatar
walleyfisher
still can be the relay,
relay is off power flows from relay to resistors to motor,
relay is on power flows from relay to motor direct
Old Oct 8, 2020 | 01:55 PM
yelo80vette
Nope. Afraid not. Just a Hanes manual.
Old Oct 8, 2020 | 01:57 PM
yelo80vette
I'm almost positive I checked it when I tried to solve this problem before, but I'll check it again. Thanks.
Old Oct 8, 2020 | 11:41 PM
7T1vette's Avatar
7T1vette
It also can still be the switch. Checking continuity on a switch will not [necessarily] indicate a fault-free switch. If the contacts are burned and carbon covered, they can still show continuity (with relatively low resistance); but they might not be able to transfer adequate current to run the blower. That switch can be opened to clean the contacts, then put back together if undamaged and still serviceable.
Old Oct 9, 2020 | 01:31 AM
yelo80vette
I'll try it. Thanks !
Old Oct 9, 2020 | 05:54 PM
SwampeastMike's Avatar
SwampeastMike
Does the blower run at low speed whenever the ignition switch is at "RUN"? It should. Put the key at "RUN" without starting and you should hear the blower run. The LOW speed setting on the fan switch has no function due to an electrical bypass around the switch to provide "constant ventilation" as the feature was called.
If it does not run constantly at low speed then given what you've already done (did you test the old blower motor before going to the extreme amount of work to replace?) I would first suspect the high-speed blower relay. It's on the firewall on the passenger side and has five wires in the connector. Three are heavy 12 gauge and are red, dark blue and purple. DISCONNECT the negative battery connection and the connector at the relay. Using a test light check between the relay connections made by the dark blue and purple wires. No or dim test light? Clean the connections thoroughly and test again. Still no or dim test light? Replace the relay.
If the fan does run constantly write back with that info and I'll give more troubleshooting information.
Old Oct 9, 2020 | 07:23 PM
68blvert's Avatar
68blvert
from a 1982 but should be same if not similar
To The Impossible Blower Switch Problem Challenge !
