Detailing battery compartment
Old Oct 17, 2020 | 12:15 PM
johnny76's Avatar
johnny76
Cruising
Default Detailing battery compartment
Hi,
I have a 1976 C3, I'm replacing the battery and the compartment can use a good detailing. I had originally thought the compartment was made of metal as there is a "rusty" residue all over it that I was going to start sanding off. But I found on this forum the box is made of fiberglass? it looks plastic to me now. How did this rusty coating happen on fiberglass/plastic? I read something about "vents"? There is a hole in the bottom of the compartment. Would a new sealed maintenance free battery cause the same issue? What's the recommended way to clean-up and restore the box? sandpaper and black spray paint? I have some POR-15 I was going to use on the undercarriage, how about that?
Thanks. Pic below.
Johnny76
Old Oct 17, 2020 | 02:10 PM
MelWff's Avatar
MelWff
If you Google C3 battery box image you will see none of them have that coating, they are all black.
Older C3's used special battery caps that had a vent hose attached running out the bottom of the box.
Later C3' with sealed batteries or aftermarket sealed batteries do not need the special caps.
Old Oct 17, 2020 | 02:35 PM
johnny76's Avatar
johnny76
Cruising
The coating was not put on by anyone, it seems to be some chemical reaction of residue, like rust, but maybe acid? It's not 100% covered as you can see.
If the battery used was non-sealed (non-maintenance free) in the newer C3 (without vents), could this residue be produced by the battery gasses?
Old Oct 18, 2020 | 12:38 AM
SEVNT6's Avatar
SEVNT6
I bought my '76 new & I have that same overspray coating on the right side of the box.
It also has some at the rear & on the bottom. The front is clean glass.
I also noticed some bright blue metallic mixed in with the black....it's all stock.
Is your '76 red?
Old Oct 18, 2020 | 04:42 PM
7T1vette's Avatar
7T1vette
Detailing the battery compartment is like painting the coat closet....
Old Oct 18, 2020 | 05:08 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
How about scrubbing it with a brush and a box ob baking soda to remove any. Acid that has seeped into the fiberglass?
Old Oct 19, 2020 | 01:06 PM
MelWff's Avatar
MelWff
I haven't seen a battery that needs maintenance in decades.
Take a small amount of water and a small amount of baking soda and mix.
Take a small paint brush or some sort of applicator and apply it to the discolored area in a small spot to see if there is a reaction to determine if you have any acidic substance present,
To Detailing battery compartment
