Unknown sensor
Old Nov 6, 2020 | 03:44 PM
Carson75's Avatar
Carson75
5th Gear
Default Unknown sensor
Not sure what this sensor is between the exhaust ports of cylinders 1 & 3. The little tab broke off to connect the wire. If anyone knows what this is exactly I’d appreciate the help
Old Nov 6, 2020 | 04:22 PM
Lachymac1's Avatar
Lachymac1
Hard to tell from the photo on my mobile phone but from what you're describing it's the coolant temperature sender which goes into a bung in the head at that location.
Old Nov 6, 2020 | 04:27 PM
Duke94's Avatar
Duke94
I agree, temp sender.
Old Nov 6, 2020 | 10:08 PM
Carson75's Avatar
Carson75
5th Gear
Great thank you, that was a guess I had Becuase I don’t seem to have one installed near the thermostat
Old Nov 6, 2020 | 10:15 PM
Carson75's Avatar
Carson75
5th Gear
To clarify it’s the sensor I have circled
Old Nov 9, 2020 | 02:26 PM
aquaroscoe's Avatar
aquaroscoe
https://www.corvetteforum.com/forums...spark-tcs.html
Look up TCS temperature sensor
Oops just noticed that it is on the drivers side. definitely coolant sensor
Old Nov 9, 2020 | 07:50 PM
C3 4ME's Avatar
C3 4ME
That connector has definitely seen some heat, likely melted against the headers. You should look into replacing that as well as the sensor.
Old Nov 30, 2020 | 06:23 PM
Carson75's Avatar
Carson75
5th Gear
yeah she got a little toasty. I was gonna add a new crimp fitting for the spade connector. Thank you for the help
Old Nov 30, 2020 | 06:24 PM
Carson75's Avatar
Carson75
5th Gear
I appreciate the help
Old Nov 30, 2020 | 06:59 PM
SteveG75's Avatar
SteveG75
Now you get to read all the threads about how the replacement senders have the wrong resistance and cause the gauge to be inaccurate. Have fun.
I managed to repair mine when the tab broke off by carefully slotting the insulation just enough to solder a new tab in place and then reinforce it with JB weld. Been working for 9 years now, If you have to get a replacement sensor, Wilcox makes the adjustable resistor to calibrate your gauge to the new sensor.
To Unknown sensor
