Paint bubble
Old Nov 9, 2020 | 07:54 PM
Old Man in a C's Avatar
Old Man in a C
Default Paint bubble
Damn, damn, damn. I've got a paint bubble under my otherwise flawless paint job (5 years old). It's small, approximately 3/8" diameter, but definitely a bubble. I can see a very light "ghost area" of body work in a 2" circle surrounding it. My car is a light metallic gray similar to Steel Cities Gray without the green hue. I doubt it can be spot blended.
Anyone had a similar experience, and what do you do about it?
Old Nov 9, 2020 | 09:17 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
I have about 3 of them on the rear deck lid of the 72 coupe. I tried to "deflate" one and glue it back down but it would not settle back and looks slightly worse. I don't think you can do much other than to grind it out including some of the fiberglass underneath which is probably contaminated to begin with. Then repair and repaint and try to blend it in or repaint the section.
Or do what I am doing for now and learn to live with it (for now). Ike
Old Nov 9, 2020 | 10:51 PM
bobby70's Avatar
bobby70
HI guys-i have a 70 bridgehamton blue color just painted 2 month ago same problem rear deck bubbles about 5 of them today I drove the car back to the paint shop. call me when its done 1 more thing I dropped 1 muffler driving the car down there.a never ending storing
Old Nov 10, 2020 | 04:12 AM
Redvette2's Avatar
Redvette2
My bubbles match the spider cracks perfectly so I am just going to live with them. Car is a 5 mph/5 ft. weekend driver car with a 20 year old paint job and fortunately overall still looks pretty good. I would be quite depressed to spend big money on a paint job and then have this happen so I do feel your pain.
Old Nov 10, 2020 | 05:04 AM
Plasticexperience's Avatar
Plasticexperience
I use a paint guy who is mobile and all he does is repairs. Depending on the location of the blister he may be able to fix. He does all Tesla’s in the field work. I would have someone similar who specializes in spot repair. You may want to check with some of the dealerships. Bob
Old Nov 10, 2020 | 10:08 AM
71 Green 454's Avatar
71 Green 454
What area of the car is the bubble?
Old Nov 10, 2020 | 12:53 PM
sunflower 1972's Avatar
sunflower 1972
I like to peruse the C2 forum since C2's and 3's are so similar (at least suspension wise) and found this thread not too long ago:https://www.corvetteforum.com/forums...hat-to-do.html
Perhaps it will help.
Old Nov 10, 2020 | 04:02 PM
interpon's Avatar
interpon
yes that would be helpful as the halo may be back staining (like AC oil)
Old Nov 10, 2020 | 07:17 PM
Old Man in a C
Nowhere near heat or contaminant, midway between headlight cover and lower corner of hood.
Old Nov 10, 2020 | 08:06 PM
Old Man in a C
Good read, Sunflower. My bubble is small enough that I think I'll give the super glue a shot.
BTW a few years ago I dribbled a small run (2 inches) of super glue down the side of my drivers door. After a few days I figured I had nothing to lose so I hit it with acetone. Voila, it took the glue off without harming the paint.
To Paint bubble
