Help!
Old Nov 20, 2020 | 04:26 PM
Mobifire's Avatar
Mobifire
Default Help!
I was in the process of changing diff fluid. I was pouring the bottle of additive, attached to it was a small, 4 inch soft plastic tube. As i was dumping fluid in, the tube popped off and fell in. Do i have to pull diff to get it out or should i leave it or what.
Old Nov 20, 2020 | 04:46 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
If it were me I would pull the cover and get it out of there. But that is how I am. Others will argue it's plastic and will get ground up.
Old Nov 20, 2020 | 06:25 PM
KenSny's Avatar
KenSny
Common sense would say to take cover off, remove plastic tube, then you get to add all new fluid.
Why would you even think of letting the plastic grind up and possibly cause more problems?
Old Nov 20, 2020 | 06:34 PM
interpon's Avatar
interpon
Try a camera or grabber maybe you can grab it if it floats....especially if its the 26 dollar gm additive..
https://www.amazon.com/Endoscope-Wireless-Borescope-Inspection-Flexible/dp/B07Z8SQ6T5
Less than 30 bucks with coupon..hell im going to get one decent reviews
Old Nov 20, 2020 | 11:02 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
You probably don't have a drain plug. Might be a good time to drill and tap one. Maybe the tube will flush out or not. If not, I would remove the cover and retrieve the tube.
Old Nov 21, 2020 | 01:44 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
it is possible to remove the diff cover without completely dropping the diff. you need to support it with a jack and reach over the top to remove the bolts. seems everyone on this forum always say to drop the diff completely to remove the cover. but not totally necessary.
Old Nov 21, 2020 | 08:29 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Reaching over the top to remove those bolts is easier said than done but it is doable. I find it easier to remove the cross member bolts and lower the whole unit.
Old Nov 21, 2020 | 09:32 AM
Mobifire's Avatar
Mobifire
yeah i mean i just put it back up in the car in may so it should be pretty straight forward. Just a dumb mistake i didnt have to make. Im gonna attempt to use one of the camera thing to locate it and possibly grab it with a tool i have. If im gonna have it back out i might as well replace my clutch packs and stuff.
Old Nov 21, 2020 | 11:05 AM
standardbyke22's Avatar
standardbyke22
sorry to hear.
i would overfill the diff and hope the tube floats and flushes out of the fill hole.
then i would try one of those mechanic claw tools
if no luck id pull diff.
Old Nov 21, 2020 | 11:58 AM
Mooser's Avatar
Mooser
Not helping your problem (the gears are probably going to grind it all up, my luck it would end up in the bearing somehow) but for the next time...
Use a needle or T-pin
to pin the tube to the bottle nozzle
M
Old Nov 21, 2020 | 02:09 PM
71 Green 454's Avatar
71 Green 454
Originally Posted by standardbyke22
sorry to hear.
I agree, I would probably jack up the drivers side and put it on 2 jack stands. Overfill the diff. and see if it floats to the fill hole.
Or, attach a hose to an old shop vac that fits into the fill hole and see if it will suck the plastic tube enough to remove it.
Good luck.
Old Nov 21, 2020 | 05:26 PM
7T1vette's Avatar
7T1vette
If it was flexible plastic, you have little risk of doing any significant damage. That being said, the plastic tube SHOULD float on the dense diffy fluid. If you can come up with some kind of long-nosed tweezers or forceps, you should be able to grab it with some patient "fishing".
If you can't get it out, don't lose any sleep over it....
Old Nov 21, 2020 | 05:45 PM
Mobifire's Avatar
Mobifire
i got another tube just like it, put it in the container of fluid and it sunk after about 1 minute. I think ill just pull diff apart this week.
edit: is there any fluid i could put in diff that it would float in? Maybe automatic transmission fluid?
Old Nov 21, 2020 | 09:50 PM
7T1vette's Avatar
7T1vette
The density of the fluid must be higher than the density of the plastic. My mistake.
But, the risk to any metal running parts from that flimsy plastic is not worth worrying about, IMO.
P.S. You can still try 'fishing'. I have one of those flexible 4-pronged "grabbers" I inherited from my Dad (many years ago). It has come in handy for things like your situation. I once dropped a wiper door shoulder-bolt down the "fender hole of DEATH". Finally fished it out with the 'grabber'.
https://www.walmart.com/ip/Hcinere-F...076410&veh=sem
Old Nov 21, 2020 | 10:47 PM
Mobifire's Avatar
Mobifire
tried fishing it out for 2 hours. You thinking i should leave it?
Old Nov 21, 2020 | 11:30 PM
forman's Avatar
forman
dont give up,, keep fishing it out you cant leave it in there
Old Nov 21, 2020 | 11:59 PM
Vette5311's Avatar
Vette5311
I agree, you need to get it out.
Old Nov 22, 2020 | 03:37 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
If you have a cheap scope with a monitor....suction the new fluid out.....use the scope to see the tube....use the flexible mechaic's fingers to extract the tube....if all that fails...rebuild the internals and remove the tube..
Old Nov 22, 2020 | 03:23 PM
7T1vette's Avatar
7T1vette
Wow. I've seen differentials which had metal pieces running thru it and had NO external symptoms that any operational defect existed. I can't imagine that the little plastic tube would offer and resistance or obstruction to gears, bearings or bushings in there.
But, if you must get it out so that you won't lose sleep, disassemble it.
To Help!
