Cheap C3 seat belts?
Old Dec 14, 2020 | 06:52 PM
78vette5.3's Avatar
78vette5.3
Default Cheap C3 seat belts?
Anyone run eBay cheap seat belts? Seems a lot say fit the 68-82 corvette and they look like the style I have in my 78. Mine are very worn and in bad shape and wanted to replace. They are the ones up in the sail panels 3pt I believe but the car has never been together and it’s basically a shell with no interior. The belts are in. If they don’t really retract or anything.
like this style
https://www.ebay.com/itm/1-Pair-Univ...4AAOSwi5xeThv6
Old Dec 14, 2020 | 07:44 PM
Richard454's Avatar
Richard454
I went inexpensive-thinking going cheap on seat belts that are questionable quality -doesn't sound like a great idea.
Went to the junkyard-pulled some rear seat belts out of Mercedes IIRC 600 SEL- looks like they had never been used- great shape- really nice material. New these thing are probably a grand+.
I was all in for $20-25.
Others have used the rear seat belts out of 97-02 Firebird/Camaro
Mine look like this-
https://www.ebay.com/itm/Mercedes-Be...-/173865586890
Old Dec 14, 2020 | 07:53 PM
oldgto's Avatar
oldgto
"Cheap" and "C3" are not terms that usually go together. When I search Ebay,
I always used the advanced search, and exclude the word "fits".....
it cuts out a LOT of the generic "one size fits all" type of entries.
Old Dec 14, 2020 | 08:00 PM
78vette5.3's Avatar
78vette5.3
I read about the 4th gen firebird seat belts and what’s interesting is that I have 2 spare sets just lying around. But looking at the mods looked like a good bit of work obviously if I could get a generic set
to bolt in for $70 that’s worth less than my time but like everyone has said it’s not a place to skimp. They look like some are SAE rated which is why I was asking about them.
Old Dec 14, 2020 | 08:03 PM
Shovels and Vettes's Avatar
Shovels and Vettes
You could just tie a rope around the seat, and make a square knot each time.
Old Dec 14, 2020 | 08:35 PM
78vette5.3's Avatar
78vette5.3
I’m an Eagle Scout.... don’t tempt me! Ha
Old Dec 14, 2020 | 08:46 PM
cv67's Avatar
cv67
St. Jude Donor '05
Whats the best and cheapest rope...I bet a slipknot would make a good neck restraint? Asking for a friend thx
Old Dec 14, 2020 | 10:33 PM
7T1vette's Avatar
7T1vette
If you have the old belt set, just have it re-webbed. New webbing material sewn to the stub-end of the retractor webbing, and other fixed belts just with webbing replaced. The "risk" part of buying old belts is that they may have 'seen' years of sunlight and be considerably weakened from the UV rays. That destroys plastics over years of seeing sun.
Old Dec 15, 2020 | 11:00 AM
cheapta's Avatar
cheapta
I bought from a company called Retro Belt for my 76, they're the dual retractor style. I got them through Summit Racing in the correct color.
Good luck
Peter
Old Dec 15, 2020 | 11:59 AM
L-46man's Avatar
L-46man
"The feeling of (cheap) immortality extends right until the moment of impact"
I am constantly slayed by my fellow Corvette builders, who are building a sportscar worth tens of thousands of dollars and decide to cheap-out with safety of flight items.
Hmm,. lets buy the cheapest...
Tires, brakes, seatbelts, steering coupler, ball joints etc.
Nobody dies on my watch!
Unkahal
Old Dec 15, 2020 | 07:45 PM
flyeri's Avatar
flyeri
This is what I did. I had a local aircraft interior shop sew the ends on. They did this for new a/c interiors so they had the proper technique down pat.
Old Dec 16, 2020 | 02:21 AM
Iceaxe's Avatar
Iceaxe
I don't know what you consider cheap. But I replaced all the seat belts in my 70 with new belts for $180.
Seat Belts Plus
Ssatbeltsplus.com
A set of generic lap only belts can be had for under $40.
Old Dec 16, 2020 | 05:42 PM
Boundstaffpress's Avatar
Boundstaffpress
I have purchased cheap seatbelts from amazon. They are sitting in the envelope as the return shipping was too much. I was wanting to put a center seat belt in the back seat of my VW beetle. In the end, I purchased used buckles, new correct webbing, and correct bonded thread. I hand sewed the webbing in the same pattern as the originals with the same spacing. It was very inexpensive, looks good, and is as safe as if I had a local shop sew them. By the way almost every upholstery shop can sew seat belt webbing. They probably even have your color in stock.
To Cheap C3 seat belts?
