71 Manual Window Regulator Question
Old Dec 30, 2020 | 10:06 PM
Norm07's Avatar
Norm07
Default 71 Manual Window Regulator Question
Can anyone tell me if there is a difference between the right and left manual window regulators. I suspect that I might have mixed them up after I took the doors apart. From what I recall turning the window crank clockwise when facing it lowers the window and vice Vera....is this correct?.
Old Dec 31, 2020 | 02:09 PM
62corvette's Avatar
62corvette
If you mixed them up, you would have bigger problems than “which way do they crank”?
Old Dec 31, 2020 | 04:03 PM
'75's Avatar
'75
Drivers side door, clockwise rolls it down. The white one is drivers side I believe.
Old Jan 1, 2021 | 10:26 AM
Norm07's Avatar
Norm07
Thanks for the Pic....I think you are correct.
Old Jan 1, 2021 | 12:35 PM
7T1vette's Avatar
7T1vette
They are different (parts books show different P/N's for each). Whether you can switch sides with them and have them operate well (except in reversed rotation of handle) is something I do not know.
Old Jan 1, 2021 | 01:04 PM
Norm07's Avatar
Norm07
i have numbers on them but I can’t locate anything that corresponds. The only difference is they travel an inch further in one direction, other than that they are identical. I have found a few pictures that show the springs hook from the bottom so that’s what I am going with...but who knows I could be pulling them out and swapping them....we will see...thanks for your input.
To 71 Manual Window Regulator Question
