Mechanic
Old Feb 22, 2021 | 05:50 PM
  #41
Mr D.'s Avatar
Mr D.
Go checkout this thread in the C2 section, procedures are the same for your car.
https://www.corvetteforum.com/forums...-cylinder.html
Old Feb 25, 2021 | 06:56 AM
  #42
Mr D.'s Avatar
Mr D.
Any update on your brakes?
Old Feb 25, 2021 | 09:08 AM
  #43
michaelroy's Avatar
michaelroy
Tried the repositioning of the prop valve using the stomp on pedal method. NO LUCK. Only have flow from valve to rears. I was going to remove the valve, took off 2 lines and thought better of that while lying on my back. Not sure what to do. Thanks for thinking of me.
Old Feb 25, 2021 | 09:33 AM
  #44
Bikespace's Avatar
Bikespace
That is frustrating. If you can't get it reset, I s'pose you'll have to remove the valve and reset it on the bench.
Did you try doing it with a helper? Here's one more video to watch (start at 3:30).
Old Feb 25, 2021 | 09:51 AM
  #45
Mr D.'s Avatar
Mr D.
What was the outcome of post #40?
Old Feb 25, 2021 | 01:55 PM
  #46
michaelroy's Avatar
michaelroy
I am walking away from this car for the time being. We have a place at Myrtle Beach and I am gonna go watch the Atlantic come and go. One problem, as I see, is that the more things you try the more things that had done before gets screwed up again. I am brain dead!
On the positive side a mechanic I have faith in has agreed to help when I return. I have a friend that has a nice drive-on trailer that i'll use to transport car to the mechanics shop. In the mean time I want to thank everyone that has responded to my post. Stay tuned.
