riser
Old Feb 19, 2021 | 06:06 AM
harmoe's Avatar
harmoe
Default riser
would i create more vaccuum by adding a 1" riser to the carb (Holley 770 cfm )
Old Feb 19, 2021 | 10:04 AM
pltmgr's Avatar
pltmgr
I don't think so.
Old Feb 20, 2021 | 07:08 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
it will increase signal in the carb for the fuel but will not change the vacuum to run accessories. for that you need a timing change, a cam change if theres a lot of overlap in your grind, or you can add a vacuum pump
Old Feb 20, 2021 | 08:33 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Old Feb 20, 2021 | 09:16 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
No......and if you run one, it must be a 4 hole on a dual plane intake.....an open spacer will puke the carb signal and it will run worse everywhere.
I put a 1/4" phenolic spacer on just about everything I build.....but mostly for heat insulation.
Jebby
Old Feb 21, 2021 | 06:04 AM
derekderek's Avatar
derekderek
another way to increase vacuum is fix the vacuum leaks...
To riser
