Distributor Cap Window
Old Mar 15, 2021 | 06:33 PM
prowlerboy's Avatar
prowlerboy
Default Distributor Cap Window
Looking for info on how to practically use the distributor cap window to adjust points. Seems much easier just to take the cap off. Is this why this unique feature (the window) was ultimately removed from distributor caps? Cannot seem to find much info about this at the usual internet sites.
Popular Reply
Mar 15, 2021, 08:06 PM
Factoid's Avatar
Factoid
Here’s my tool from back in the day.
Old Mar 15, 2021 | 07:06 PM
kanvasman's Avatar
kanvasman
This brought back lots of memories in my fuzzy old brain. I cannot imagine trying to set the dwell and removing the cap. How long must that take and how accurate could it be. The window works perfectly if you have the right tool. I got this a very long time ago and it makes this proecedure simple and quick.SPring loaded so it bends easily I even had an engine with dual points to do this with. Here is the tool that I still have although I most likely will never use it again.And I suppose the advent of electronic ignitions caused GM to close the window...sorry I couldn't resist.
Old Mar 15, 2021 | 07:08 PM
wilcar's Avatar
wilcar
Gm got rid of points distributors after 1974 and went to the HEI distributors so no need for a window. I agree with you that is easier just to remove the cap and adjust the points. That's what I do too. If you have a dwell meter you can still use it with the cap off .
Old Mar 15, 2021 | 07:27 PM
PJO's Avatar
PJO
Veteran: Marine Corps
With a dwell meter this is the most accurate way to adjust points. Here's one on ebay cheap.
https://www.ebay.com/itm/Snap-On-MD-...YAAOSwKmVefBFG
Old Mar 15, 2021 | 07:30 PM
Greg's Avatar
Greg
Just another Corvette guy
kanvasman nailed it. It is MUCH easier to adjust through the window, while running, provided you have the correct tool and it works on any angle.
In the points era this design once again put GM ahead of the blue oval and pentagram crowds.
Old Mar 15, 2021 | 07:35 PM
HeadsU.P.'s Avatar
HeadsU.P.
Wonderful tool shown. Unfortunately, it only fits vans with a 454 in California. Or not.
I remember when a set of points & condenser came with an allen wrench. With a dwell meter laying on the Intake and the 283 idling, that little window in the cap made quick work of a otherwise pita job. Best invention since sliced bread. No more loosening the points. No more feeler gauge. No more taking the cap on & off.
Dwell setting first.
Then IGN timing second.
Old Mar 15, 2021 | 07:42 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I have one of those tools out in the garage, works great.
Been at least 15 years since last use tho.
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Thanks for the link, I just bought it.
Old Mar 15, 2021 | 08:06 PM
Factoid's Avatar
Factoid
Old Mar 15, 2021 | 08:14 PM
HeadsU.P.'s Avatar
HeadsU.P.
Gauge & Flashlight too.
Old Mar 15, 2021 | 08:15 PM
Aquarian's Avatar
Aquarian
Great memories...Have one of the snap on tools in the box...but you cant beat the old match book for repairs on the side of the road..
Old Mar 15, 2021 | 10:07 PM
prowlerboy's Avatar
prowlerboy
Thanks guys, I just joined the site and this was my first question. Appreciate the quick responses and humor.
Old Mar 15, 2021 | 11:26 PM
Mod75's Avatar
Mod75
Off the top of my head i am going with 0.15/0.17
I could be wrong tho.
Old Mar 16, 2021 | 12:29 AM
7T1vette's Avatar
7T1vette
That metal window in the cap is flimsy. To tell the truth, I always just lift the window to max position and pull outward to put a little bend in it....just enough that it won't fall down. The 'cable' Allen wrench is a useful tool. But when you don't have to hold the window open, you can easily adjust the dwell with a long-shank Allen wrench. When done, just bend the window back straight and drop it down.
Old Mar 16, 2021 | 08:15 AM
Mr D.'s Avatar
Mr D.
My go-to when playing with points.
Old Mar 16, 2021 | 01:07 PM
wilcar's Avatar
wilcar
Thank you for that! Old school rules!
Old Mar 16, 2021 | 06:49 PM
kanvasman's Avatar
kanvasman
I have told people about the old matchbook trick and they never believe me. Try fixing your ecu with a matchbook.
Old Mar 16, 2021 | 07:52 PM
Factoid's Avatar
Factoid
Well, you could light it on fire!
To Distributor Cap Window
