Side mount header muffler
Old May 13, 2021 | 08:22 PM
c5c6c7's Avatar
c5c6c7
Default Side mount header muffler
Any one have any experience with the Doug's High-Flo side pipe muffler inserts...
I'm running open headers right now and it's just to loud. And I don't want to get pinched for the noise....
Do the High flows kick it down enough to get me out of a ticket?
Old May 13, 2021 | 08:53 PM
gtwhoa's Avatar
gtwhoa
I like the vettepack mufflers I have on mine.
http://www.classicchambered.com/clas...html#corvettes
Old May 13, 2021 | 09:53 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I always get "quiet" inserts for my Harley and Vette....if they are too quiet I drill/enlarge the holes in the insert until I get the sound I'm comfortable with.
Old May 13, 2021 | 11:56 PM
Bikespace's Avatar
Bikespace
A previous owner welded 18" of cherry bombs at the end of my Hooker headers, and used 4" truck stack pipes as the extensions. They are basically open pipes, so I'm following for better suggestions.
I've read on the Forum (but not heard in person) that the spiral inserts are worth considering.
https://www.spiralturbobaffles.com/
Old May 14, 2021 | 04:31 AM
wendellp601's Avatar
wendellp601
I have Doug's inserts in my side pipes.
At normal cruising speed, you can carry on an conversation with the other person in the car.
At wide open throttle, they're pretty loud.
Side note - If you do go with these inserts, you can wrap them with DEI titanium header wrap before sliding them into the side pipe.
With my wrapped inserts, I can put my bare hand on the pipe where the insert is after a 30 minute drive.
Old May 14, 2021 | 08:36 AM
jim-81's Avatar
jim-81
Not sure if this answers your question but I had the Doug's medium loudness ones before I switched to Vettepacks. Here is thread and video:
https://www.corvetteforum.com/forums...ettepacks.html
Old May 14, 2021 | 09:10 AM
c5c6c7's Avatar
c5c6c7
Thanks, That was really great!
Old May 14, 2021 | 09:42 AM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I went with the Spiral Turbo Baffles ( https://www.spiralturbobaffles.com/ ) years ago in my Hookers.
They are all metal with nothing to wear out. I even modified the central tube so I can easily unblock it when I want the extra flow when at the track.
I've been very happy with them.
Old May 14, 2021 | 11:48 AM
todds74's Avatar
todds74
Billy Boat Exhaust makes side pipes that are insulated and flow well. They say you san touch them and not get burnt. They claim no heat shields are needed. I have some ordered now so no personal experience .
Old May 14, 2021 | 11:51 PM
TimAT's Avatar
TimAT
I have the STS baffles too, Not real bad until you get in the pedal.
Old May 15, 2021 | 09:55 AM
c5c6c7's Avatar
c5c6c7
Thanks for all your replies...I decided on the Doug's D952's...
I called tech support at Doug's and the guy said that the D952's were discontinued because they were too loud..
So I found them somewhere else and went with those,
My wife is gonna be pissed
Old May 17, 2021 | 04:24 PM
eff10mm's Avatar
eff10mm
Not as pissed as she will be when her leg gets burned. My wife burner her leg for the first time on the sidepipe this weekend. I forgot to remind her to be careful before we got out. I run the STS spiral baffles in mine and like the sound by the way/
Old May 17, 2021 | 04:59 PM
titanle's Avatar
titanle
agreed. They work great and still make the car sound mean.
Old May 18, 2021 | 03:09 PM
Corey_68's Avatar
Corey_68
Had several mufflers as well as open pipes....STS Baffles, Hands Down.
To Side mount header muffler
