Offset upper A arm shafts.
Old Jun 23, 2021 | 06:48 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Default Offset upper A arm shafts.
I know I have seen something in the past wherein offset upper A arm shafts that fit other Chevy's will also fit our C3's. when looking on Summit's site. nothing is listed for C3's.
Certainly someone out there knows what other Chevrolet's take the same upper A arm shaft and or where to get affordable offset upper A arm shafts.
Thanks much for any information.
Old Jun 23, 2021 | 08:58 AM
Fly skids up!'s Avatar
Fly skids up!
I copied this cross-reference list for you.CHEVROLET BEL AIR 1965-1970 CHEVROLET BISCAYNE 1965-1970 CHEVROLET CAPRICE 1966-1970 CHEVROLET CORVAIR TRUCK 1961-1964 CHEVROLET CORVETTE 1963-1982 CHEVROLET ESTATE 1969-1970 CHEVROLET IMPALA 1965-1970 CHEVROLET KINGSWOOD 1969-1970 CHEVROLET TOWNSMAN 1969-1970
Old Jun 23, 2021 | 09:53 AM
Eric P's Avatar
Eric P
I did offset shafts on my 80 to get more Caster , I just called the local auto parts store and ordered them , I don’t recall them being over 20.00
Old Jun 23, 2021 | 10:03 AM
Fly skids up!
When I did my front end early this year those shafts were difficult to find. So I understand the OP situation. Hopefully stock on everything will continue to increase.
Old Jun 23, 2021 | 10:14 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Global West
Old Jun 23, 2021 | 10:17 AM
Eric P's Avatar
Eric P
With bushings, I did mine last year . K6184 is the Moog part number
Old Jun 23, 2021 | 07:13 PM
Aquarian's Avatar
Aquarian
One of the threads here has some great info on this
'tubular a-arms' a few years old but worth the read.
Found these parts I was planning to get for mine..."upper and lower tubular a-arms for 56-64 Chevy Belaire and Biscayne"
Old Jun 24, 2021 | 04:35 AM
4-vettes's Avatar
4-vettes
I looked REAL close at this photo. definitely does not look like a offset shaft to me. bolt holes appear to be perfectly centerd.
Old Jun 24, 2021 | 10:13 AM
Eric P's Avatar
Eric P
What ? Picture is a little deceiving because it's at a angle but even so the outer threaded shaft center line is still below the bolt hole center line plain as day , order up a set at the local parts store , you will be happy
reno stallion
You can't see the offset? I surly can. Look at the one's I posted do you see the offset on those? It's not the mounting holes
Old Jun 25, 2021 | 05:53 AM
4-vettes's Avatar
4-vettes
Okay, I looked again. I was looking for offset to achieve more caster. moving the arm rearward, would achive this. moving the arm downwards?? purpose? please explain.
Old Jun 25, 2021 | 06:22 AM
sw69vette's Avatar
sw69vette
Installed MOOG # 6104 on my 69 L46.
Old Jun 25, 2021 | 12:17 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
As far as I know, the primary task of the Moog "offset" arms is to locate the shafts that the arms pivot on, on an axis that is further outward, in order to correct for "sag" in the frame. The Global West shafts may also have the means built into them to alter the caster, but it's hard to see, in the pictures.
Old Jun 25, 2021 | 12:47 PM
Fly skids up!
If I recalled the offset shaft or 1/8" shims changes camber by 1 degree. So if a offset shaft is used and two 1/8" shims in the rear, camber should remain the same while increasing positive caster. OP any reason why you feel you need more caster?
Old Jun 25, 2021 | 12:51 PM
Eric P's Avatar
Eric P
I used mine for more Caster when I rebuilt the front end and installed a Core support .... I did my front end restoration of the car first which was front suspension , core support and engine and it had no rear shims for maximum positive Caster already on the front control arms .... It drove nice for dry rotted bushing so I added shims to compensate for the added offset until I had time to rebuild the rear suspension and went 700R4 before doing a 4 wheel alignment which the suspension actually was done last winter ... Fast forward up to a few weeks ago when I did the alignment I was able to get 4.5 degrees positive caster at zero Camber with my black 80 L82 and still have about three shims in the rear where it had none before
Old Jun 25, 2021 | 09:59 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
What I found out was the stock arms only let you go to about 2.5 to 3.0 caster. Then you have a lot of rear shims but the limiting problem is you have no shims in front and cannot tilt the a-arm back any further for more caster. (Assuming you are trying to keep your camber where you had it.)
The offset arms let you angle the front in more, and push the ball joint back more, for more caster.
Old Jun 26, 2021 | 08:10 AM
4-vettes's Avatar
4-vettes
A few questions to answer. why do I feel need for more caster. Simply put, with my wide tires and the rough roads here in Australia. my steering feels very light. I have a stack of shims on the rear bolts of my upper A arms and none on one side and one on the other. Still inadequate caster. Also no budget for aftermarket A arms. would like to get some caster to put some "feel" into steering. The budget method is to use offset A arm shafts. Big name brand super expensive parts cost 3 times as much for me over here so please spare me. So far part numbers supplied have given me replacement bushings. (No good) And parts that I can not find through google or Summit . A part number that can be found with a Google search or from a company that ships to Australia for a reasonable price would be greatly appreciated. And truthfully, I am still trying to understand how a downward offset can work. really need rearward offset to get more caster. Thanks Guys for any help. I really do have a limited budget. I can pull this apart and put it together. would just like to get rid of this super light feel.
To Offset upper A arm shafts.
Old Jun 26, 2021 | 11:25 AM
Fly skids up!
Jegs has them.
https://www.jegs.com/i/Delphi/117/TC6504/10002/-1
While on the subject, I thought I needed the offset shafts. A lower ride height (1 inch) used all of the available adjustment. New springs and correct ride height, plenty adjustment left. And for what it's worth, the non A/C springs gave the correct height in my 82 A/C car. The A/C springs gave it the "Carolina Squat". Didn't mean to hijack, just trying to pass along information.
Old Jun 26, 2021 | 12:28 PM
sunflower 1972's Avatar
sunflower 1972
Have you considered slotting the upper control arm shafts to gain more positive caster?
https://www.google.com/search?q=slot...WQWCzEQ4dUDCBA
Old Jun 26, 2021 | 05:39 PM
4-vettes's Avatar
4-vettes
I looked at Jegs link. no photo. nothing in the description says anything about offset. googled the Delphi part number. found a number of places have them. from one photo I found it looks like there offset for camber, not caster. But nothing in the description other than stock replacement. A bit worried about having something shipped overseas that just won't work. Slotting my arms may be the only answer if no one makes them. I do not own a mill nor have access to one. So I would be at the mercy of a machine shop. Most likely cost more than buying new shafts plus the extra down time. So still looking for a affordable shaft offset rearward.
