76 Corvette door handle
Old Jun 26, 2021 | 12:07 PM
mikem83's Avatar
mikem83
Default 76 Corvette door handle
My 76 Corvette door handle has the droops and from my research it is a broken door handle spring. I searched and found several of the good parts sights are selling a door handle pop up spring helper. Has anyone here used it and does it work.
Old Jun 26, 2021 | 12:19 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I used the spring helper. Worked for a few years and then it broke and jammed underneath the door handle which required leaving the window down to open the door from the inside. I managed to slip the broken piece out from under the door handle. Now my door works again but with a drooped handle. My advice is to live with the drooped handle or replace the door handle.
Old Jun 26, 2021 | 02:17 PM
derekderek's Avatar
derekderek
replacement is the only viable fix. the hinge pin is riveted in. you grind the end off and drive the pin out and find a homedepot spring that works and then you have to do some epoxy or soldering method the keep the hinge pin in place.
Old Jun 26, 2021 | 03:10 PM
Peterbuilt's Avatar
Peterbuilt
The springs are a good temporary fix, my temporary fix has lasted several years!
Old Jun 26, 2021 | 04:07 PM
HeadsU.P.'s Avatar
HeadsU.P.
Save your money on those quick to fix, quick to break gizmos and do it right.
Look around on EBay for a drivers side handle assembly. Be leery of import stuff. The chrome will wear off soon. You will see a wide range in prices on EBay.
I found a original GM NOS drivers side handle, still in the bag, on EBay for less than $35. Quality chrome, perfect fit.
Sometimes a C3 owner passes away and leaves boxes & boxes of NOS parts behind for the family to discard / sell.
Inner door panel will have to come off. Not a horrible job but need small hands.
Old Jun 26, 2021 | 07:11 PM
Z06LMB's Avatar
Z06LMB
Replacing the handle is the only logical choice. When done, it’s done.
Beware the cheap knockoff handles do the same thing you have now. I can tell just looking at the cheap replacements - the reveal around the moving part is wider and many times doesn’t return up to the top. And of course the color and evenness of the chrome is off.
A word of advice, don’t drink too much caffeine before working on this replacement - it can be very frustrating if you have big hands!
Rich
Old Jun 28, 2021 | 11:53 AM
Kerschmolar's Avatar
Kerschmolar
Corvette Central part#283011L fit my driver side perfectly and looks great after 5yrs.($40). Tried helper spring first without success.
To 76 Corvette door handle
